bolt and nut, all mine are
G'day. I bought universal camber tops (that you drill to suit) but they don't come with the studs as supposedly you use the one's from your original top hat.
I emailed the guys and they said they can't supply them either.
Any ideas where i'd go about purchasing said studs?
ok, have you got a good, nut and bolt store locally or something???, go there with the camber top (drilled) and they may have studs to suit or very close
Nuts and bolts out in norchy. Have a chat to them, if they don't have it your stuffed hahah
If you have original Top hat. Screw the nut onto the studs and hammer them downwards, they will come out
dose
assume that are all 80s car, or even corolla family related, im sure toyota used all the same studs for the top hats..you should be fine =]
dose
Well it's for a ke10So i want to keep my original strut tops. I just knocked some studs out of ke70 one's which look the same just a little bit shorter.
The ke10 has a hat that sits over the strut top so i can just bolt that over the top of the camber top for stealth
I also had ke55 one's but they're much thicker than 70 ones.
Cheers for the help!
