Upgrading my setup, so this gear is up for sale.
1. Bosch 5 bar(165 litres/hour) high pressure fuel pump. Used, but in good working condition. Some superficial marks. Supported my 230kw turbo motor without an issue. Will supply with new terminals and a red anodised clamp. $80ono.
2. Stainless 1.75L ish Surge Tank. It's a work of art. 4 bosses with brass barb fittings installed already. Perfect welds. Traditional style. $70ono.
3. Alloy 1L ish undercar surge tank. 4 bosses. It's a bit shit - But it would work well once repaired. (It needs a small tig weld on the base to complete.) $20
4. Approx 5-6 metres of high pressure efi hose and a bunch of small efi hose clamps to suit. Used, for about 12 months. $30
5. 3x Bulkhead type fittings with 90 degree barb on one side, straight on the other. Used to transfer fluid between two seperated spaces. eg, boot to under the car. $20
If you buy the lot, I'll supply a low pressure filter for your lift pump, a high pressure filter for the pump, more fittings and hose clamps... Will post pics if there is interest.
All located in Ripponlea (Near Elsternwick) Victoria.
