Also forgot to add it comes with an oil cooler w/ lines & fittings
Selling my engine setup that I had for the wagon..
Has:
7A block (suits reconditioning, all parts here to put back into it)
20v silver top head (Suit reconditioning, stripped at the moment but have all parts here still to put back together if you wanted)
20v pistons (Used, good condition. Need new rings)
JDM 4AGE alternator mount
JDM water pump
SPOOL forged rods with ARP bolts
Cusco Engine/gearbox mounts (Stiffer than stock and lowers engine ~10mm)
Toda adj. Cam gears
4AGZE oil pump
Quad throttle bodies, sprayed in heat proof black. (Been stripped down and cleaned. Injectors haven't been installed back in there, but they're hanging around somewhere)
KOYO AE86 aluminium radiator, brand new never fitted to a car.
Water setup is pretty much there, running a JDM 4AGE water pump and rear head outlet. Will still need a small blanking plate for the back of the head and to drill/tap the back of the head to secure the plate. Top outlet needs to be sorted out too.
Also have a cut loom out of an ae101 for it.
It'll take a bit of work to get it together and running, but for what you get here and the amount of money I spent on parts this is an absolute bargain! Head/block alone cost me $900!
Looking for $1000 pickup. Located in Sydney, Pm me if you're interested. Can upload photos if anyone wants..
SOLD![]()
