Results 1 to 10 of 10
Thread: RCA's
    Senior Member GOODY's Avatar
    Logan
    Default RCA's
    After a cheap 2nd hand pair of normal RCA's for 86 struts. I'm using ajps 8kg springs so I think about 40mm rca's are what I'm after?
    Show me what you got
    Logan
    Thanks mate I've had a browse through your threads and if I can't find any cheapy 2nd hand ones I'll be in touch.
    Veteran blair's Avatar
    Blair
    SEQ
    the spring rate isnt really what determines if you need RCA's..
    the ride height is. they are put in place to correct the LCA angle
    Logan
    Yeh I realise that but I said that I had 8kg ajps springs which give a certain ride height in the front right??
    Blair
    SEQ
    no. you can get any length of spring you want??
    edit: sorry, not meaning to be hostile..
    8kg spring will always have the same amount of droop no matter what lenth
    but differennces in free hieght (uncompressed lenth) can vary anywhere from about 180mm to say 250mm?
    Logan
    Ahh ok I think I understand what you're saying, I was just under the impression that if I had these certain springs then they would always require the same size rca (40mm) to get rid of bump steer, unless they had been cut etc.
    But just to clarify, should I take any sort of measurements on the car or should 40mm be what I'm after?
    Dave
    The Ghetto
    are you running longer control arms or stock? If you are 40mm should be fine, if u want slightly more camber 30mm nrca will do the job for stock arms. Either way both reduces bump steer. Hope that helps
    Logan
    Yeh I'm running xt130 lca's so I'm not after nrca's really, thanks for the help
    Anyone got any laying around they don't want..??
    i have brand new 40mm rcas with bolts $110 posted
    Logan
    You're a bit cheaper than ajps so same goes, if I don't find anyone wanting to get rid of 2nd handies then you will be hearing from me
  1. 30mm RCA's
    By 70XIN in forum Car Parts For Sale
    Last Post: 28th May 2012, 08:43 AM
  2. RCA
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 11th August 2011, 02:56 PM
  3. New Ra60 Rca's
    By Low Style in forum Car Parts For Sale
    Last Post: 16th October 2009, 07:11 PM
  4. Rca
    By reecegze in forum Cars or Parts Wanted
    Last Post: 24th March 2009, 10:45 PM
  5. rca vs. nrca
    By johl in forum Technical - Questions
    Last Post: 10th April 2008, 12:45 PM
