well it sounds like you are on the right track. you have voltage at all the correct places with the key on.
there are 2 additional earths that are on the 18 pin plug (centre plug) those wires are also brown. According to the wiring diagram, they earth all the sensors including ECU.
Note that the dizzy wires are also on this plug, this may or may not be your problem.
