Results 1 to 9 of 9
Thread: LSD into T series open centre question?
    Member Alexrex7's Avatar
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Default LSD into T series open centre question?
    Recently purchased a t series open centre out of a T-18 and have heard the axles are slightly longer than the LSD counterpart by 5mm or so and that you need to grind this off to fit an LSD? is this true theyres just a bit of mixed info on the net? also i can only fit a zenki diff not kouki right? any help would be appreciated
    Oct 2010
    Dogan
    Tulla
    Yes you can only use a zenki LSD with the t18 axles.
    With the axle length q, I have got a trd 2 way with stock standard t18 axles which have not been cut. No problems. I can't say about other LSDs but with the TRD LSD you will have no problems using the stock axles
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I am pretty sure you only need to cut the axles when you use the RA40 ones in the housing
    Senior Member Stain's Avatar
    Derek
    Far North
    never heard of having to cut axles.
    I have a series 1 t18 diff with a zenki trd lsd in it so I know that combo works
    Andrew
    East Melbourne
    As far as I know, only the t-series axles from a disc brake rear end are 7mm longer. I actually have one of these axles at home.
    I have read that these need to/can be be trimmed down to work in TRD LSDs only. Kaaz and others apparently accommodate for the extra length.
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Yea so stick with zenki then i see. Well its a relief knowing i wont have to cut off my axle and arsing round with that. Also i called toyota before and apparently they have discontinued TRD 2 ways?? any one know someone else i could call to get one? cheers for that guys
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I'm guessing you called a local dealership? They're mostly hopeless with sourcing that kind of thing, won't ever look at toyota stock that isn't in australia. I worked for toyota/nissan for a while, better off trying importers or performance workshops.
    Aug 2010
    Geoff
    mt dandenong
    importmonster, i've been looking at them too, same boat as you with the t18 diff etc otherwise try AJPS or justjdmimports
    Jason
    Southern Suburbs
    I think its only factory LSD that require shortened axles, which are few and far here in OZ.
    RA60 is a wider diff so obviously they axles would require shortening for T18 diff usage.
    RHDjapan/greenline can get brand new LSD's.
  1. WTB: T-series open centre
    By AE86slut in forum Cars or Parts Wanted
    Last Post: 13th December 2009, 10:59 PM
  2. VIC wanted s series open centre
    By sprinter666 in forum Cars or Parts Wanted
    Last Post: 30th November 2009, 08:19 PM
  3. VIC: Need S series open centre and someone to fit it
    By lugnut in forum Cars or Parts Wanted
    Last Post: 20th November 2009, 02:41 PM
  4. WTB S Series open centre diff
    By keto 4122 in forum Cars or Parts Wanted
    Last Post: 10th September 2008, 07:58 AM
