G'day, had similar work done to my smallport before i re-assembled engine myself
-Hot tank clean block, crank, pistons/rods
-Block hone and surface
-Clean & crack test head, clean & machine valves & seats, fit new valve stem seals, re-assemble valves & buckets, surface face, and check & reset valve clearances
-Supply new rings & bearings and full gasket set
Cost close to 2grand, and i still had to assemble bottom end myself.
Hope this gives you an idea of what you are up for, but well worth it I think, hands down heaps more power than my brothers shagged smallport had!!
