Results 1 to 10 of 10
Thread: sr20 into ke70.wiring help!
    Apr 2012
    hayden
    wairarapa
    upperplain
    new zealand
    Default sr20 into ke70.wiring help!
    hay guys im currently putting sr20de vvti engine in my 1987 corolla wagon but iv come to a hault as its time to do the wiring but to be fully honest i have no idea what im doing.iv got the ke70 loom in and most of the sr20 loom but have no idea what to do next so really need some help.i got told that i only really need a few wires owt of the sr20 loom to make it run and main power to the ecu,starter,altanater and hook up ignition. is this correct? any help would be great
    Apr 2012
    hayden
    wairarapa
    upperplain
    new zealand
    The basic logic i've found with "most" efi cars i've worked on is
    Find the high amperage output wire(s) of the efi relay and that takes care of your injector, dizzy , coil power.
    Power the ecu with constant + switched ignition power
    Then sort out your fuel control (AFM / ECU)
    Then sort out your accessories - Idle control, oxygen sensors, alternator, starter motor
    Then sort out your ecu inputs ELS# wires, basically inputs for when your thermo fan, blower fan (heaters) are running etc.
    For around $500 odd you can usually pay someone who will knock it over in a couple of hours. If you were in australia , it'd be easy to recommend a heap of people. If you are doing it yourself and it is the first time, then it is 10000x easier to do with both looms side by side off the car.
    If you can't find someone, grab the sr20de vvti wiring diagram and post it up here. Work on it 1 wire at a time and when you get stuck, ask a few questions and i'm sure someone will know the answer.
    If you haven't already get yourself a multimeter with a continuity buzzer and you'll be loving life
    Apr 2012
    hayden
    wairarapa
    upperplain
    new zealand
    dear i say it that still sounds confusing haha from the ecu i have pluged in evry thing such as dissy afm 02 sencer injecters and what not once i connect my constant power to the ecu and connect up the starter to the ke ignition am i in the right direction?
    That is a start, but there is quite a bit more to it than just that. My post above at a very high level sums up what you need to do.
    Grab your wiring diagrams and learn what each wire on the ecu does, then learn what sensors need power. Adapting looms to suit different cars, in most instances there is only a handful of wires to worry about on the ecu itself, 90% of your time is spent doing the other things.
    The other thing i didn't say you have to do is all the cluster gauages / warning lights.
    Apr 2012
    hayden
    wairarapa
    upperplain
    new zealand
    yea probly a good idea ill try find a diagram and see what i can do
    Biggest problem with starting the job yourself and not finishing it is very few auto electricians will touch it as they first need to learn what you've done and it is a pain in the butt
    Veteran Skylar's Avatar
    Ken
    Also, don't jerry rig that shit. Buy a fuse block like and do it properly. Put the red wire on a separate fuse not in that ignition switched only fuse panel.
    Ken
    errr, I can't be bothered typing anything out so here's a post I wrote earlier this week,
    Apr 2012
    hayden
    wairarapa
    upperplain
    new zealand
    nah i dont intend to jerry it up ae wana do it once and do it right
  1. wiring up a sr20
    By alan-ae86 in forum Technical - Questions
    Last Post: 26th July 2012, 11:36 PM
  2. Replies: 4
    Last Post: 31st January 2012, 02:14 PM
  3. sr20 wiring
    By sr86ftw in forum Technical - Questions
    Last Post: 22nd May 2010, 10:34 PM
  4. SR20 redtop ECU WIRING
    Last Post: 28th March 2010, 12:35 AM
  5. SR20 into KE70 wiring info
    By Simon-AE86 in forum Technical - Questions
    Last Post: 20th June 2008, 08:14 AM
