just go aftermarket sway, they are cheap already
Hey guys just wondering wat rear sway bars are similar or the same as an ae86 rear sway bar, and has anyone found a budget way to upgrade the rear sway bar or just buy an aftermarket one
dose
I have a budget option, a custom set of clamps to fit a second stock bar on, by positioning the clamps it also makes it adjustable
Ohk yh will look into that anything would b better than no swaybar as mine dost have one or mounting points so ill have to make them up,r ke sway bars the same??
ke bars will fit
was it toyota tercel that i heard would fit?
yup, thicker then stock 86's. good luck finding one though.
i've heard the double up method that sam was talking about works well
