Results 1 to 10 of 11
Thread: 4age timming
    Veteran Rice86's Avatar
    Richard
    Liverpool
    if you follow the 4age engine manual that will give you a rough idea on where the 2 dots on the cam gears should be..but STILL need the backing plate to line it all up correctly unless your happy to take your chances..
    dose
    Richard
    Liverpool
    dose
    Senior Member KAYE70's Avatar
    Apr 2012
    aidan
    nsw
    kellyville
    Default 4age timming
    Hey all just put a vrs kit in my 16v 7 rib
    I do not have a cam backing plate which has the timming marks for cam gears to line up to.
    Is there anyway to time it without the cam gear backing plate or do i start hunting for one?
    Heres an old pic of motor after i crashed the last ke70 so u can see it with no backing plate Click image for larger version.
    Stern but now fucked off...
    May 2005
    Nick
    timming?
    seriously?
    Buy the backing plate... Kind of important to get right
    Apr 2012
    aidan
    nsw
    kellyville
    I can take my chances. There floating vaulves. There fore wont hit pistons if timing is out.
    Ill try get a backing plate tho because i want to out cam cover on anway
    Apr 2012
    aidan
    nsw
    kellyville
    Wat u trying to get at?
    Apr 2012
    aidan
    nsw
    kellyville
    Will try and find one. On bit of a toght sqeduele to get this motor in
    Unless you've changed the cams you won't have an interference engine anyway... it is the amount of lift which makes it interference etc.
    Apr 2012
    aidan
    nsw
    kellyville
    Motors only been rebuilt to standard. So no interferance
  1. cam timming using std beams for vvti
    By Celica RA45 in forum Technical - Questions
    Last Post: 29th July 2012, 10:49 PM
  2. 4age timming belt covers
    By KAYE70 in forum Cars or Parts Wanted
    Last Post: 12th June 2012, 08:19 PM
  3. beams single vvti head and timming covers
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 14th September 2011, 03:49 PM
  4. Aftermarket Computer with Fuel and timming adjustments
    By rgeorgiou in forum Car Parts For Sale
    Last Post: 11th April 2009, 04:21 PM
  5. 4age cam timming (belts n stuff)
    By starni_boy in forum Technical - Questions
    Last Post: 28th May 2006, 07:10 PM
