RT142 Corona Wagon
22RE
5 Speed
200,000 ks
Silver with blue interior
T series rear end out of RA60 with appropriate tailshaft to suit
DEFECTED
Info:
I purchased this car defected about 12 months ago. It requires regency park inspection.
Work left to do:
Reconnect brake lines front and rear and bleed brakes
Reconnect hand brake cables
Check and tighten diff trailing arm bolts after I had installed T series
Install rear half of tail shaft
Install replacement radiator and run and bleed cooling system (supplied with car)
Install replacement battery (supplied with car)
Change sump
Degrease and clean engine bay for inspection
Clean inside and out to make all pretty for big date with Regency
I think that is all it needs from memory.
Car will come with a set of Corona Avante wheels with good tread.
Price - $1300 FIRM.
As these have a 22R the engine is popular amongst Hilux owners and carries a high value. If I parted it out (which I will in 7 days) I would get my $1300 back in parts. This is the reason the price is firm.
Here is a pic, apologies for it being covered in 3 inches of dust but it has been stored for a year now. I don't have any other pics and it would be best to come view the car if you are interested. Realistically this car needs a day spent on it to bring it up to a standard for inspection and then the inspection itself. I have acquired a new project and barely have the time for that let alone this car.
Contact Luke on 0430 181 590
Car is located at Brompton, Adelaide
The car will remain for sale for 7 days after which I will commence parting it out
