Hi everyone,
After a few hours of searching and only turning up lots of threads with replies "this topic has been done before, search for your answers" and no threads with actual answers, I've turned to asking the question.
Does anyone ACTUALLY have the info on doing a digital dash conversion?
I will do a write-up when I do the conversion but there are things I'm yet to find out.
Wiring differences & extra sensors.
Do you actually need to change any harnesses or can the existing wiring simply be modified?
I have found that you need an oil pressure switch & a fuel level sender to suit the digital dash, does the sender actually need changing or is it just a resister or circuit that changes the signal for the dash?
Is the oil pressure switch non-existant with the normal dash or is it just a different sensor?
Cheers.
