Results 1 to 3 of 3
Thread: 4age no spark... Help wiring issue I believe
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    Default 4age no spark... Help wiring issue I believe
    Hey everyone,
    We have just put a 4age into a ke70 and have it all wired up. Went to kick it over last night and there is no spark. I have looked around on the net for a wiring diagram for the igniter but I cannot find anything to double check what we have wired in. Is there anyone that can help us out with this?
    Veteran slide86's Avatar
    Huw
    Hills
    Veteran Skylar's Avatar
    Ken
    Yeah bro.
    Is it a old bigport type with the 5 pin minitimer plug? Or a newer one. because the minitimer ones have the pins written on the bottom of them so you can figure out what wire to put where, if that's the info you're looking for.
    Are you sure it's not a CAS issue? Does the fuel pump prime when you spin the dizzy gear?
  1. Headlight wiring issue
    By barnzy - ksev in forum Technical - Questions
    Last Post: 5th May 2010, 09:34 PM
  2. lights wiring issue
    By ke70astro in forum Technical - Questions
    Last Post: 2nd August 2009, 11:10 PM
  3. help needed, something to do with battery, spark issue
    By hara_kiri in forum Technical - Questions
    Last Post: 14th June 2008, 05:50 PM
  4. wiring loom issue
    By sik-86 in forum Technical - Questions
    Last Post: 13th May 2007, 10:56 AM
  5. 4AGZE spark plugs Mis fire issue
    By D1 in forum Technical - Questions
    Last Post: 15th January 2007, 06:02 PM
