Results 1 to 8 of 8
Thread: omfg help please :( :( :(
    Member 96sonataBro's Avatar
    Mar 2012
    Hugo
    W.A.
    s.o.r
    Default omfg help please :( :( :(
    so i went to remove my exhaust side camshaft today (removing head), and the first bearing cap bolt (cyl 4, LHS) is completely rounded by previous owner. I actually have no idea what to do and its quite depressing. can anybody please help. will show some pics of my secrete super cool sprinter build in return
    Veteran slide86's Avatar
    Huw
    Hills
    vice grips..........
    Aug 2010
    Geoff
    mt dandenong
    you can buy special tools to get rounded nuts off, or like slide said vice grips or worst case weld a old socket onto the rounded off nut. i would not recommend bashing on a smaller socket incase you ruin something else.
    Adan
    Oxley Park
    drill the head off the bolt?
    Cut the head off with a grinder?
    Smash a smaller socket onto it?
    Weld a bar to the bolt?
    Id probably try the vice grips first though...
    Is it a bolt you need to remove or just a nut?
    If it is a bolt, buy a set of these.... Have saved my ass a few times
    Start with vice grips first tho , and buy a decent quality brand screw extractor if you go down that path , the cheap sets do SFA
    Moderator Sam-Q's Avatar
    Endeavour Hills
    post a pic of the bolt in question
    Mar 2012
    Hugo
    W.A.
    s.o.r
    dw all good, i don't no why i didn't try vice grips in the first place, thanks slide. every face on the nut was striped bar one so i managed to get a good grip and crack the ####. i deal with this problem with a grinder all the time but i didn't think it was very appropriate for this situation, being a cam bearing cap and all. i was so excited i had to go do it just then, now i can sleep tonight man i love these forums, i dunno what id do without them thanks for the quick response everybody
    Veteran Skylar's Avatar
    Ken
    3/8 long neck socket might do the job unless it's completely rounded. but like meadan said, there are many ways to fix this.
    Edit: I take too long to post.
  1. Replies: 4
    Last Post: 30th May 2011, 10:33 PM
  2. OMFG look whast for sale in J-LAND
    By tin can in forum General Topics (No Technical Questions)
    Last Post: 20th May 2010, 12:22 PM
  3. omfg. coolest, angriest 180 in excistance
    By scott_22 in forum Offtopic Discussions
    Last Post: 13th March 2009, 08:15 AM
