Results 1 to 9 of 9
Thread: noisy 4 link
    Aug 2010
    Merrimac
    Default noisy 4 link
    Hey guys,
    Just installed a adjustable 4 link into my ae86, it has nylon lined rose joint end, and its really noisy/knocky while i'm driving. Is this normal noise from these types of joints? Before anyone asks, yes all the bolts are tight. I can feel a fly shit of movement in the joints, i bought these arms a few years back in a group buy, but never installed them till just now.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I could be wrong but it sounds pretty normal to me, the person you bought them off should of told you about that.
    Aug 2010
    Merrimac
    ok sweet, i knew they would be noisy, just not like this. Is there any sort of grease or other lubricant i can use on the joints to reduce the harshness of the knock?
    Aug 2010
    Geoff
    mt dandenong
    [QUOTE=mrmatt;873564]ok sweet, i knew they would be noisy, just not like this. Is there any sort of grease or other lubricant i can use on the joints to reduce the harshness of the knock?[/QUOTE
    im pretty sure sams right, every car i've been in with anything rose jointed is always noisy, sounds like half your suspension is loose. i think thats why rose joints are a track based thing.
    Veteran stahlz_ae86's Avatar
    Paul
    Great for side to side load (panhard/LCA's), but not so much for front to back (caster/trailing).
    Aug 2010
    Merrimac
    Yea it sounds like the arms are floating around. i'm just tuning my ears to ignore it, so far so good. I got a slightly buckled rim on the back which makes them vibrate like crazy at anything over 100kph.
    Apr 2010
    Mike
    sam-Q would having rosejoint on the diff side and nolthane bush on the body side make it much better?
    Veteran AJPS's Avatar
    Lonsdale
    yes, thats the set up I sell and use in my car, MUCH better
    Veteran Skylar's Avatar
    Ken
    If anyone is going to put adjustable 4 links, it should be that way and that way only.
    OR bush/bush if they want it more street-ey. AJPS/Superpro ultra hard bushes in stock arms.
    Fuck solid/solid 4-link bars for non-equal length trailing arms.
    Some reading:
  1. Noisy Drivetrain
    By Tom86 in forum Technical - Questions
    Last Post: 28th May 2010, 11:29 PM
  2. noisy T series
    By w84me in forum Technical - Questions
    Last Post: 12th July 2008, 09:54 PM
  3. NOISY DIFF, NEED HELP
    By dr1ft-pig in forum Technical - Questions
    Last Post: 30th June 2008, 02:37 PM
  4. Noisy box
    By hilltop_hoodlum in forum Technical - Questions
    Last Post: 23rd March 2007, 01:28 AM
  5. Why are old engines so noisy ??
    By broke in forum General Topics (No Technical Questions)
    Last Post: 26th July 2006, 03:56 PM
