Hey guys, I know there's a thread here somewhere outlining this but I've run into an issue.
I'm using a W55 for my 20v conversion and if I remember correctly, the thread I mentioned above stated that you use the W55 throwout bearing and clutch fork. However, my clutch fork which is apparently from the W55 doesn't fit the throwout bearing I received with the gearbox.
The fork doesn't actually fit around the throwout bearing when trying to match them up in your hands and when inside the bellhousing, it's too short to reach the bearing...
The only explanations I can come up with are,
A) I've been given the wrong clutch fork.
Or
B) I need to use a 4AG/T50 clutch fork.
If anyone can let me know what they've used for their setups, or can shed any light, It'd be greatly appreciated.
