nice car, could you explain what you mean with the diff?
ra65 diff is F series and is it welded or 2 way lsd?
Selling my RT142 corona wagon with the 22re 5 speed engine which is a pretty rare combo the engine has done 270 000ks which seems high but being the 22re (same engine as the hilux's) seems pretty low. Has 1 rust hole in the front quater pane other than that the car is pretty clean! does have a slight noise coming from the timing chain, i have bought a new timing chain kit to go with the car i just work big hours and dont have the time to put it in
they make about as much power as a stock 4age with some decent mid range torque and only weigh 1000kg, with extractors should notice a decent power/torque and response gain. Rolls on s13 sr stockies with 185 55 15 achilles
im in the middle of putting a ra60 diff in it which t series lsd's, 2ways, 1.5 ways will bolt straight in, ive just welded the gears up 3.9 gear ratio with all new bushes in the rear end.
looking for $2200 negotiable
0431 784 0 1 1
its a ra60 diff sorry, welded not a 2way
Ah gotcha, good luck with sale,
Solid buy for the price, GL with sale.
