Results 1 to 8 of 8
Thread: Pulling down a 7afe engine - Removing crank bearing caps
    Default Pulling down a 7afe engine - Removing crank bearing caps
    Hi All,
    Just in the middle of pulling down my 7afe block and i've called it a day, but couldn't get the crank bearing caps in the middle out. These are the ones which have the thrust washers either side...
    What is the secret to getting these out? The other caps came out easily, but these ones won't wiggle enough to get them off.
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    hey matt, use an aluminum or brass drift with a hammer and tap it left to right, foward and aft. it will come loose
    Ok
    Seamus
    Milton
    Just literally drop two main bolts in (dont thread them), and then hit them one by one with a hammer (from the side). Works everytime
    ^ Clicky clicky!
    Too easy, was trying to be gentle... Looking forward to getting this built
    Veteran timbo's Avatar
    Tim?
    Wild West
    As toxin said. It actually says this in the Toyota repair manual.
    I'll do it tonight, I got all the others out with my hands, just the ones with the washers either side got stuck.
    Apr 2010
    Mike
    and i found using a clean(no molested) pry bar, worked well if you have studs instead of bolts
    Took all of 30 seconds last night to get them out... Bolt in the cap, taped with a hammer and out they came.
    Thanks seamus and tim
  1. Replies: 0
    Last Post: 17th September 2012, 11:51 AM
  2. bigport head n 7afe engine help
    By kid redonkulous in forum Technical - Questions
    Last Post: 20th June 2012, 11:17 AM
  3. removing crank timing belt sprocket
    By Tim.duncan in forum Technical - Questions
    Last Post: 9th December 2009, 01:39 PM
  4. removing center tailshaft bearing
    By Stej in forum Technical - Questions
    Last Post: 3rd May 2009, 03:10 AM
