Hi guys,
I have a bigport 16v with S/T 20v quads. It runs factory ecu and loom but the tps is not connected due to the 16v loom plug being different to the 20v one. Anyone know what I can use, change plug or tps?
Cheers,
Grab a 20v tps plug, pretty sure i'll have one in the shed you can have... When you wire it, it needs to be done "backwards" as the 20v throttles spin the opposite way to a 16v.
Read that and you should be well and truly on your way. Personally i'd run an aftermarket ecu, but it should work ok on the 16v one...
