hey hey hey!
i'm helping brokenships with this... and can't figure it out for me for the life of me...
this is exactly what is happening. The car will run for a while and then stop... doesn't conk out, just stops dead, no spluttering, just dies. After this happens, the car will NOT start... I fiddle with the coil, check all the wiring, everything is connected correctly. The computer is getting power, the Ignition module is getting power, the wiring from the ECU to the ignition module is all hooked up perfect. Take the lead from the coil to the dizzy, ground it... nothing. When it won't start, I put a test light (screw driver with a light in it) to the connection from the module to the coil, and it stays solid. When the car DOES start (sometimes when warm, sometimes when cold...), the test light will flash, then it starts. We have replaced the coil, checked allllllll the wiring, and it just keeps starting intermitant...
Can anyone confirm weather there should be two connections to the coil??? at the moment, there is a connection from the battery to the coil, and another from the ignition module to the coil... i'm thinking that may not be right??
The timing is a bit off, but it definatly isn't the cause of this issue... like i said, it just DIES... DEAD... running, then nothing...
any clues???
