Results 1 to 8 of 8
Thread: Identify these calipers please
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    Default Identify these calipers please
    Car - Ae86
    motor / part in question - Front calipers
    problem - Don't know what its from
    occurs/started when (if applicable)-
    personal situation (if applicable)-
    Howdy, I have calipers here I took off my adm ae86 thinking they were adm calipers. However, I bought some coilovers that came with adm calipers and they turned out to be very different to the ones that came off my car. I searched the numbers but only came up with a reference to a T-18 caliper? Here are some pics next to the 2014 adm caliper:
ID:	25992 Click image for larger version.
    Cheers,
    Veteran timbo's Avatar
    Tim?
    Wild West
    girlock, ke70?
    Dec 2011
    Kerry
    Warradale
    do the calipers bolt on to the backing plate on the new coilovers?
    if not can you take photos of the two backing plates side by side?
    my guess would be ke70 calipers
    Veteran shift_rook's Avatar
    SE Burbs
    could very well be t-18 calipers. Same strut pacings at the bottoms, could have been replaced at some point in its life without anyone noticing, easy enough struts to come across
    Aug 2010
    Adrian
    South
    xt130 has girlock brakes yeah?
    Tim?
    Wild West
    At least some did
    Mar 2012
    Eastern burbs
    I'm pretty sure they do, can't get the backing plates off of the coilovers at the moment because I can't get the hub off! But since everyone seems to be in a identifying frame of mind, can someone tell what hubs these are? The hubs that are off are 'supposedly' ae86 hubs, don't know what to expect with this car anymore. Pics:
    unknown hub ^
    ae86 hubs ^
    Jake
    Northgate
    Definantly don't look like T18 calipers, T18 aren't a fully floating caliper, and T18 calipers do not "bolt" strait on to any other struts that I know of, pretty sure they can be put on ke70 struts with little modding.
    Hubs I am pretty sure you can just measure the bearing size, but T18 and ke70 hubs don't fit on AE86 stub axle from what I have tried personally, may be able to fit ae86 bearings and races to then and they may fit, but I am unsure of that.
  1. Identify this please?
    By Ktas in forum Technical - Questions
    Last Post: 22nd April 2012, 12:46 PM
  2. Identify my axles!
    By blair in forum Technical - Questions
    Last Post: 27th July 2010, 09:28 PM
  3. identify these 2 flywheels ?
    By .ady in forum Technical - Questions
    Last Post: 20th December 2009, 11:01 AM
  4. difference between adm calipers and jdm calipers
    By benzo in forum Technical - Questions
    Last Post: 26th August 2009, 07:02 PM
