Results 1 to 10 of 10
Thread: fuel problem
    Senior Member Shitbox's Avatar
    Mar 2010
    Raymond
    Western Suburbs
    Default fuel problem
    Was wondering how to tell whether I have a fuel pressure regulator failure or fuel pump failure.
    so I have a 71 with a 4ag twin 45 carbed and run a speco fuel pressure reg and a facet electric fuel pump. I went out tonight and drove the car pretty hard then it started to die i was pushing the accelerator and nothing would happen loss of power and just sounded like the carbs were sucking a fuck load of air. I checked the fuel reg gauge and showed 0.5psi i left the car sitting for a bit and then it was ok for a while but the pressure never rose back to where it should be 4 - 5 psi.
    So pretty much want to know whether people reckon its the fuel pump or regulator cheers.
    83' KE70 4AGE'D
    84' AE71 4AG Twin 45 DCOE webers
    Senior Member Dylan's Avatar
    Dylan
    Whats the specs on your Facet fuel pump, as far as I know they are self regulating. Also how is it wired up?
    Mar 2010
    Raymond
    Western Suburbs
    not sure on the specs of it as it came with the engine i bought but yeah i have an adjustale regulator after the fuel pump.
    also today i checked the fuel pressure and everytime i accelarated it would drop to one. I let it warm up and drove round for abit it seemed fine and the pressure went to about 3ish psi but had my regulator set to 5 as i revved it it just stayed on 3psi. So im not really sure what the problem is.
    83' KE70 4AGE'D
    Site Supporter Javal's Avatar
    Josho
    My money says the facet pump has eaten a dick / is getting too hot. Is it engine bay mounted?
    I had a case a few years back where a friend of mines car would cut out / severely lose power after a thrashing as the facet pump would get too hot and cut out, however under normal driving conditions there were no problems.
    Mar 2010
    Raymond
    Western Suburbs
    yeah sounds right think it haqs eaten to much dick it just happens after a thrashing its in the engine bay it never used to do it though. but also my fuel pressure still doesent sit where i want it at 4 or 5 psi should i change the pump.
    83' KE70 4AGE'D
    Josho
    You can try relocating it to a cooler location, like under the car near the fuel tank or in the boot.
    Alternatively you can use a low pressure rotary / vane fuel pump (again, mount it somewhere other than the engine bay) such as one available from holley. A rotary / vane pump is much more reliable than a facet pump.
    Mar 2010
    Raymond
    Western Suburbs
    Is this the one your talking about
    would I be able to run it without a fule pressure reg since it flows at 4psi?
    83' KE70 4AGE'D
    Josho
    flow does not equal pressure.
    Josho
    Double post.
    Mar 2010
    Raymond
    Western Suburbs
    yeah i might grab it and still run the reg then
    83' KE70 4AGE'D
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. Idle and fuel problem, running rich
    By capatown in forum Technical - Questions
    Last Post: 6th December 2010, 10:36 PM
  3. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
  4. Fuel problem?
    By KE70 in forum Technical - Questions
    Last Post: 15th April 2009, 01:05 AM
  5. Fuel Overflow Problem - Any Suggestion???
    By joshcris in forum Technical - Questions
    Last Post: 30th March 2008, 04:00 PM
