Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
Thread: hydrolic handbrakes whats best?
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default hydrolic handbrakes whats best?
    as topic states im sick of my cable setup and am looking for a hydrolic setup and i wanna know whats the best and i know its not g4 or d2 cause they are shithouse as im sure beau knows i want to know
    1. where to but
    2. rough cost
    3. brand
    4. and your rating on the particular model
    also how are they hooked up as im running a drum rear end do i have to run a bias control or 1 way valves?
    mat
    the dyno pull to 300rwkw
    Senior Member OMG866's Avatar
    Nick
    Miranda
    so nobody is using hudrolic hand brake setups?
    Senior Member n00bvak's Avatar
    Novak
    SOR
    using d2 from just jap with willwood proportioning valve.
    Works fine and can either be normal position or high position its also very sturdily constructed . Remember, its just a master cylinder mounted with a handle, you could spend more and get the same thing really.
    Or if you want to do it cheaper / "better quality" make it yourself. I cant weld so I bought this.
    This is how I have mine setup,
    to see the rest, check out my build thread on my sig.
    I kept my original handbrake there as well just incase I need to park outside my house, which is on a big hill
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Veteran Beau's Avatar
    Beau
    drums? hyrdo?
    E-Famous (Remeber your roots)
    I'd assume this is for a disk setup..
    Site Supporter Javal's Avatar
    Josho
    Not one of you has spelt 'Hydraulic' correctly yet.
    But noobvak has the right idea.
    Veteran bigm's Avatar
    Gold Coast
    i have a racing logic one,
    will let you know how it goes on friday
    Novak
    SOR
    drums rear. The brake place (perth brake parts) said this is how they setup line lockers for the drag guys with live diffs, and it should be sweet. I also thought this is how they setup dirty ibis in drift battle, cant be sure though, beau should know.
    Basically from the proportioning valve on it goes :
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    best is to make your own,go buy a mc from brake place make it exactly how u want and make it work exactly how u want!!!
    I make mine in my green 86 and will be making one for my ke70!
    AE86 THE BEST
    Gone
    Joel
    Picton
    Absolute best ones ive seen, but u pay for them .. are from Stewart Wilkins motorsport, they come in 3 differnt styles, normal pull up... vertical pull and vertical push ( rally style)
    he doesnt have pics.. and the pic of the one isnt the ones he makes.. they are way better..
    i cant find a pic anywhere... grr
  1. is it worth going skid pan with no handbrakes?
    By b1gb3n in forum The Drift Channel
    Last Post: 30th July 2011, 01:32 AM
  2. ae71 hydrolic clutch pedal box
    By maners in forum Cars or Parts Wanted
    Last Post: 15th May 2011, 05:28 PM
  3. Ke70 manual cable pedalbox.. NOT hydrolic!!
    By corey70 in forum Cars or Parts Wanted
    Last Post: 6th March 2010, 11:48 PM
  4. ae71 hydrolic cluth into a ke70
    By DRF17 in forum Technical - Questions
    Last Post: 13th April 2008, 09:29 PM
  5. Handbrakes!
    By DriftPlease in forum Technical - Questions
    Last Post: 31st July 2006, 10:06 PM
