hey guys im new to this thread. im after some help. im building a 7afe with a 16v bigport head (standard head). turbo on the side of course. im getting a spool import stroker kit of make it a 1901cc.
1. would i need to rebuild the head with valves and turbo cams.
2. what gasket do i use. is it a standard 7afe gasket.
3. what belt should i ran.
4 there was no crank pulley on my 7a block. what crank do i run. can i use 4age one fit.
i called spool imports he ask me to find out
1. compression chamber volume
2. head gasket volume
so he can make pistons to suit.
hopefully someone can help cheers.
