Do you have spark?
Check power at the ECU if the check engine light won't come on, both the constant power and the ignition power. Also check your brake fuse as allot of ppl hook into the brake lights for constant ecu power as it is done that way factory in cars of the same era..
TE,E1 are the terminals to bridge for the check engine light.
Also dbl check your earths are tight, from batt to chassis and also the brown clump that bolts (i think near the throttle body).
I'm not that far from you so if you can't sort it out , flick me a pm and i might be able to drop by later this evening.
