Results 1 to 10 of 11
Thread: Installing AE86 struts & brakes to AE71
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Default Installing AE86 struts & brakes to AE71
    I have recently purchased AE86 Struts, brakes, hubs and lower control arms.
    I want to install them into my AE71 and just want to know how difficult this is and what I should be aware of?
    Everything looks simple except for the brake calipers? I have never removed and installed calipers before.
    Should I replace the wheel bearings before installing the hubs?
    Is there anything else I should have checked out or replaced by an expert before doing this?
    Also should I get a wheel alignment after the install?
    Thanks for any help
    Aug 2010
    Sutho Shire
    its simple youll be right,when u take a wheel off you will see exactly what u have to undo in order to remove strut,control arms ,brakes,new bearings are good to start fresh, get the disks machined up if abit messy and lipped up and wheel alignment is good idea,hubs need to be off in order to tap out wheel bearings,to remove old ones i just used a old braker bar put it through the center hole in bearing and with hammer bashed it out turn over and repeat,to install you have to take ur time,get a socket the same diameter as bearing so it touches the outer steel ring and tap in making sure to hit in square or youll damage shit,a press or something would be ideal
    Senior Member Moebius's Avatar
    Christian
    When I did this on my ae71 I had to get new brake lines as the fittings between the hard lines on the car and the lines from the calipers didn't match.
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Didn't match? You sure you put on ae86 ones on then?
    bursting ovaries since 92'
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Where is the best place to get Brake lines from?
    Do I need to ger AE86 ones?
    Jun 2009
    Blake
    Penrith
    Your ke70 ones will work. I used em when I put my ae86 ones in
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    But can you buy them from a parts store?
    i would prefer to just replace them
    Veteran AJPS's Avatar
    Lonsdale
    i have adr approved braided lines in stock
    Veteran anastasios's Avatar
    Taz
    Earlwood
    I just did this in my 71. Use the 71 strut tops on your struts as you will not lose castor. (is this only ke70? correct me if im wrong)
    get a torque wrench and download an ae86 manual and torque bolts correctly.
    use ae86 brake lines as they are bigger and have the correct female fitting on the end to go into the ae86 caliper. (hmmm well i did use jdm calipers, not sure if adm is the same)
    instead of using a socket to do wheel bearings i just use the old bearing and a sledge.
    also are your springs captive? if not ziptie them to the spring perch
    Christian
    Pretty sure It's a good excuse to get braided lines anyway. Got mine from ajps.
  1. Ae86 struts - ae71 brakes/hub
    By tc-rolla in forum Technical - Questions
    Last Post: 14th July 2012, 08:43 PM
  2. ae71 ae86 brakes, struts
    By ke_70_blue in forum Technical - Questions
    Last Post: 23rd April 2010, 08:04 PM
  3. ae71 dash matt, ae86 struts, adm brakes
    By shakes in forum Car Parts For Sale
    Last Post: 19th June 2009, 01:58 PM
  4. Replies: 5
    Last Post: 7th May 2009, 11:42 PM
  5. AE86 front struts & Brakes (Adjustable Shocks)
    By Da_Hachi in forum Car Parts For Sale
    Last Post: 21st January 2009, 01:06 AM
