Results 1 to 5 of 5
Thread: Switching SC14 pulley - positive manifold pressure & brake booster vacuum questions?
Threaded View
    Mar 2011
    Ali
    Default Switching SC14 pulley - positive manifold pressure & brake booster vacuum questions?
    Car - KE70 Wagon
    motor / part in question - ST20V, GTIR intake, SC14 & Razorback ECU.
    problems - Switching SC14 pulley with Razorback ECU, Positive manifold pressure and brake booster
    occurs/started when (if applicable)-
    personal situation (if applicable)
    Hey all,
    So my razorback ECU manual says that it has an output for VVTi/Supercharger.
    I take it means 1 or the other, not both....and that is it set by RPM
    My plan was to retain the stock VVTi, so I am wondering on how to switch the supercharger pulley......
    Like I could just literally put it on a switch, meh don't really like that idea.
    Or piggy back a relay off the VVTi rpm setting....meh kinda shit idea
    I would like to trigger it with TPS%.
    Is there a way of at say 75% Throttle to trigger the SC14 clutch?
    I am thinking of calling Sam from Razorback and asking how to go about it, or if I can send him my ECU to add this option or something like it.....
    The Stock GZE ECU triggers it off HG readings right? like 8HG
    So could I hook up some kind of a pressure switch to the plenum or a vacuum line?
    Also been looking at this pretty closely and wanted to ask a few questions
    Just trying to wrap my head around this, if I 'T' together brake booster lines form 1&4 and run that with a 1 way valve to my brake booster I will still have brakes with positive manifold pressure?
    Or do I use vacuum tank? How does a Vacuum tank go when positive manifold pressure enters the equation?
    Everything i have read about vacuum tanks is for low vacuum with big cams, can't find a thing about boost applications....
    Or do i go for an electric vacuum pump?
    I think I think too much
    Thanks,
    Ali
  1. Brake Booster Vacuum Lines
    By bigm in forum Technical - Questions
    Last Post: 18th January 2010, 10:01 PM
  2. [SA] S13 (non abs) brake master, & booster
    By Tylthidras in forum Car Parts For Sale
    Last Post: 16th September 2009, 01:07 AM
  3. Installing a brake booster & m/c...need help
    By Dongaz in forum Technical - Questions
    Last Post: 6th January 2008, 07:08 PM
  4. Brake Booster Questions
    By jason in forum Technical - Questions
    Last Post: 11th February 2006, 09:11 PM
  5. 20v Brake Booster Vacuum Problems
    By sprinterturbs in forum Technical - Questions
    Last Post: 15th December 2005, 07:55 PM
