Results 1 to 2 of 2
Thread: Suspension components
    Dec 2011
    beau
    nsw
    western sydney
    Default Suspension components
    I'm curious to what type of steel is used in suspension components such as castor rods, lower control arms, panhard bars(the bar that is attached to the diff and body, I'm still learning )Also rose joints, are they all made the same?
    If all joints were rose joints would it affect rigidity in the way the suspension acts? Would it be stable?
    Gone
    Joel
    Picton
    ahh where do we start.
    stock components are made from nothing special, just steel.. i dont know what grade. some parts are cast and some are pressed and some are solid materials welded..
    steel is heavy and low grades have weakness's, to get strength out of low grades you need to compensate with thickness etc.
    aftermarket parts can be made from anything, good manufacturers use chromoly or "aircraft grade" aluminium mostly, but chinese crap is just steel and the spherical bearings.. aka rose joints have piss poor tolerances and are well known to flog out very prematurely
    all made the same?... no... some are cast and some are machined
    rode joints are a solid joint and are very ridged but don't affect the way the suspension acts.... the only point that can be argued in this case is with an unequal 4 link setup.
    other then that, they give precise driver feedback and give zero geometry deflection under load. .... but the precious drivers out there will say it increases the NHV.. or NVH ( noise harshness vibration ) but IMO this is bull crap and if your complaining about that then buy a toyota camry.
    the benefits and performance far outweighs a slight increase in noise. Thats noise you hear... not some noise thats supposed to happen on paper.
    stability ... i guess it has some affect, but stability comes more from COG ( center of gravity )
    however the car will be more responsive.
    i rate them and run them all over the car.
    brands to go for are Aurora or FK USA
    just do yourself a favour and dont buy chinese crap.
  1. Interior components wanted.
    By focus_7 in forum Cars or Parts Wanted
    Last Post: 23rd November 2012, 11:49 PM
  2. WTB: 20v components, A/C and P/S
    By van_ in forum Cars or Parts Wanted
    Last Post: 3rd July 2012, 12:21 AM
  3. (Vic) a/c components
    By BlueLevin in forum Car Parts For Sale
    Last Post: 14th February 2011, 08:19 PM
  4. a few sc12 components
    By callum1 in forum Car Parts For Sale
    Last Post: 26th May 2008, 08:07 PM
