So I've had this car for about 4 months and it's been insane, but looking my hard parked z20 just gets me down.
I've always wanted a car with 1/2jz!
So if anyone out there has a car with a 1/2jz or any other engine of interest, let me know and put me back in a Toyota!
Car is valued at 10k to give you an idea.
I would prefer call or text as I don't get on here every day. 0401485975
1990 R32 4 door (sunroof model) Imported 3 years ago so its got the side indicators
M spec
Factory turbo
Factory manual
Red
2 wheel drive
Mods:
Exterior
Roof spioler
Dmax boot wing (not pictured)
Custom side skirts (need love)
Sunroof
Genuine weather shields (ones cracked)
Gtr front bar just resprayed
Interior
Apexi Power FC + hand controller
Apexi boost guage
Apexi pen style turbo timer with afr and valtage meter on it
Decent Keenwood headunit with leads to the boot for amp (no amp included)
Engine
Internally standard RB20 rebuilt last year (new headgasket and all new belts done at the same time)
Custom built turbo by bill at ATS High flowed OP6 turbo with a huge front alloy wheel
Trust greddy front mount
Earls oil cooler and relocator
Apexi power intake
Brake master stopper
Walbro fuel pump
3" trust exhaust from the turbo back with split dump + high flow cat
Z32 AFM with brand new tomei plug
Gtr injectors
Splitfire coilpacks
Gates timing belt
Adjustable cam gears
Nismo low temp thermostat
6 Puk button clutch
Suspension + handling
Front npg Coilovers
Rear isc coilovers
Rear camber arms
Hicas lock out bar
Heavy duty whiteline sway bars front and rear
Front and rear strut braces
Adjustable front tie rod ends
Adjustable front castor arms
All new nolathane bushes throughout the car
R33 LCA's for more camber
18x9 and 18x10 Work emotion cr kais with rays wheel nuts
