Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Cam timing!
    Jon
    Durack
    Default Cam timing!
    Hi all,
    After a bit of 4age manual reading and help from 70XIN and Timbo Cam and ignition timing was spot on.
    Timbo and I took my car for a drive and it ran and drove perfectly, while pulling up to a set of lights the engine just shut down and would start..
    After pulling off my Cam covers and making sure it was TDC, I noticed that it appears my Intake Cam is nearly 180 degrees out. I made sure it was TDC 4 times to be sure i wasnt being a sped.
    Belt is still tight and I can't see any marks where it was slipping. The odd thing is this is the SECOND time this has happened.
    I can not see anything interfering with the belt or that could be making it skip, there was not weird noises it just shut down.
    The only thing I can think is that the Tensioner has moved(was/is still done up super tight). I also do NOT have the little spring for the Tensioner could this be the reason?
    Any help in why this would be occurring is greatly appreciated.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Wow, wtf! You need that spring for the tensioner , also take the the cam pulley off and make sure it still has a knock pin.
    Jon
    Durack
    I haven't pulled the cam pulley off but can see a knock pin - will try and pull it off either tonight or tomorrow night.
    Will be picking up a tensioner spring tomorrow night as well.
    Tim?
    Wild West
    Sounds good. Such a pain when this stuff happens, hopefully its an easy fix. Still such a weird thing to happen...
    Ok
    Seamus
    Milton
    The spring isn't really necessary though - alot of people actually remove it because they worry that it can come off and chew up their timing belt (club4ag and toymods). At the end of the day, he still has good tension once the engine has stopped and the belt has skipped, THAT is the wack shit.
    This one has got me stumped. Has anyone heard of a magic timing belt that stretches when running? Haha. But seriously, i can't think of any logical answer to this.
    ^ Clicky clicky!
    Ok
    Seamus
    Milton
    When it skips, are you checking the timing belt tightness between the tensioner and the intake cam gear? Because everywhere else will be tight no matter what. Just checking you're not doing a herp-derp.
    ^ Clicky clicky!
    Glenn ke_70's Avatar
    Clay
    Barossa!
    so nothing's loose/worn/fucked? balencer/cam/oil/water pump pullys, bearings ect ect
    i would check all this without the belt on.
    theres somthing broken. it's a fairly simple mechanical component. there must be somthing up.
    i'd pull everthing off and inspect it.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    when i had my 16v rebuilt with everything new, standard cams from a 4age expert, supposedly all timed up and TDC already, ready for a drop in replacement job, after a few cranks of the engine it wouldn't start..timing was spot on...more cranks and then belt jumped a few tooth..didn't release this until a week later though hahah
    lined it up again and never did it again afterwards.. so not sure what cause it but yeah has happened.. we could only think it was the tensioner so we made sure the tensioner was tight tight! and seemed to help
    now i think about it, the brand new timing belt must of stretch while cranking the engine which jumped a few tooth, after a reline and made sure its tight, was ok..or it was just loose to begin with
    dose
    All the spring is meant to do is give you correct tension during installation.
    Jon
    Durack
    70XIn – Checked and it’s the same tension all the way around – will triple check since I’m prone to herp=derping
    Ke_70 – stock cam gear, new water/oil pump, tensioner and belt – balancer seems fine as well as bearings
    Will be pulling it apart tomorrow night to see what/where if anything is causing it to skip
  1. bigport stock cam timing
    By H8CHIR6KU in forum Technical - Questions
    Last Post: 19th June 2011, 09:53 PM
  2. 7age cam timing
    By Daz32 in forum Technical - Questions
    Last Post: 10th July 2010, 01:58 AM
  3. 20v cam timing
    By NIZLAH in forum Technical - Questions
    Last Post: 29th July 2009, 09:21 PM
  4. timing a 4age with quads and 256 cam
    By dehney in forum Technical - Questions
    Last Post: 4th March 2009, 10:57 PM
  5. 20v cam timing
    By b1gb3n in forum Technical - Questions
    Last Post: 13th April 2006, 03:35 PM
