Results 101 to 110 of 192
Thread: SR20DE+T KE70 in the buildzzz
Threaded View
    Senior Member Simon-KE70's Avatar
    Simon
    Default SR20DE+T KE70 in the buildzzz - ROLL CAGE IN!!!!
    Hey all
    got sick of not drifting and the 32 is for sale... so thought i';d get stuck into building a cheap rolla up, I have to say that seeing Leigh pidwells car in action over the past year has made me want to get one, I battled him at Drift Fest last year and it was just damn quick for the basic set up it was! So i thought yeah im gonna do it lol So i started gathering bits and pieces and everything has been done so far by myself or with the help of Dec's from Garage 7 in Mt Barker and soon to be All Type Crash once i get the body work finished.
    the story goes like this. I got a stock KE, after some bitch slammed into my daily AE92 writing that off. Needed a car for work hence the stock KE, thatr lasted around 2 weeks before i blew the HG on the shitty 4k motor... so hooked up a cheap S14 SR20DE halfcut and put that in there, but i thought well since i have the whole half cut i mas as well put the rack, power steer, crossmember and susp in too.. so i did all that and drove it NA SR for a while... still stock looking with 13's and rear blinds lol... put some good 15 inch tyres on it and took it out to lala for some skids and the thing lasted 2 laps before breaking the shaft that the thrust bearing carrier runs on.... sigh... engine out job to fix since with the SR in the rolla... there aint ANY room to get to bellhousing bolts.
    It was at this point i decided f**k it... turbo it and do a bit of a build up.
    So here are the specs so far with some pics to go with it.
    Susp: S13 coilovers with AE86 tops, custom length with TRD blue shocks and a 6kg spring, custom length LCA's, bump steer adjusters, rack spacers Rear consits of TRD blue 8 way shocks and a 4.5kg spring, adjustable panhard rod and swaybars front and rear. RE001's all round and yeah... handles AWESOME.
    Motor: S14 SR20DE+T stock internals with turbo gear bolted on, Power Enterprise PE1420 turbo, braided lines, Exedy 5 puck clutch, B&M Oil cooler and filter relocator kit, Greddy intercooler
    Drivetrain: RB20 Gearbox with SR bellhousing, custom shifter location, R31 skyline diff housing and centre, currently a 3.7 will prob change to 4.1, unsure yet, mini spool to go with it, Shall be running a Twin caliper set up with one circuit for normal brakes and other for handbrake only.
    Other specs and stuff to come/go on the car:
    Hydraulic handbrake custom made, brake bias valve, water sprayer kit, custom s13 modified knuckes, R33 4 pot brakes with 4 stud rotors. and some BIG wheels.
    now for pics
    The dirty looking S14 NA motor, installed and how it looked for a few months
    Starting custom coilovers the ultimate Toyota and nissan interbreeding...
    RE001's are THE SHIT
    Put a cleaner rocker cover on
    had a decent amount of lock, will have a LOT more soon with modded knuckles tho
    Starting Stripping car....
    Dirty 31 diff...
    Firewall mods being carried out, not yet finished
    Clutch and oil line on
    Turbo on, oil return drilled and tapped, feed line on
    Thats about it currently... waiting on a few more parts and then ive got some more work to do this week on it. Pics coming soon.
  1. sr20de in ke70.
    By Nic19 in forum Technical - Questions
    Last Post: 31st August 2008, 12:12 AM
  2. sr20de ke70
    By japlish in forum Cars for Sale (Toyota Only)
    Last Post: 18th April 2008, 05:28 PM
  3. sr20de into ke70 (non turbo)
    By juzzo84 in forum Technical - Questions
    Last Post: 30th November 2006, 02:51 PM
