Results 1 to 9 of 9
Thread: Upgrade Injectors.
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Default Upgrade Injectors.
    Just wanted to know what injectors i can upgrade my n/a 16v smallport with.
    Soon to have ported and polished head, quads, 272 cams upgraded springs and valves.
    What would be the best injectors to upgrade to?
    Thanks
    Veteran Wally's Avatar
    What about GZE injectors? Thats what I'm planning. Got them in my boot.
    4AGE 16V
    Jun 2009
    Damian
    any pros or cons about them?
    pros... bigger? lawlz
    cons...?
    4AGE 16V
    Jason
    Southern Suburbs
    Keep your factory injectors.
    According to rule of thumb, 235cc small port injectors will do about 120kw at the wheels. You'll do around the 100kw mark with your mods.
    The con is that bigger injectors struggle at small pulse duration.
    A better upgrade and an good indication that toyota did their homework with the 20v (which has 295cc inj and will do 100kw atw), it the 7MGE injectors at 295cc.
    Jun 2009
    Damian
    thanks jaz86, though reason being one of my injectors is stuffed so instead of a replacement i was gonna buy others.
    so is it worth just tryna buy the one injector or go 20v?
    gay
    n1gger land
    n1gger land
    south korea seoul
    note that 20v are side feed
    Nic
    Mt Evelyn
    he means use the 7m injectors as they are the same size as 20v ones.
    Jason
    Southern Suburbs
    I ment use 7mge. I have 2 spare sets of 100kw injectors. For $40 inc freight a set is yours.
  1. 1jz injectors upgrade for 20v
    By skin in forum Car Parts For Sale
    Last Post: 22nd November 2010, 12:30 PM
  2. Replies: 0
    Last Post: 2nd May 2010, 04:13 PM
  3. 550cc injectors: Perfect upgrade for CA, SR and RB
    By crackett in forum Car Parts For Sale
    Last Post: 12th July 2009, 02:44 PM
  4. 7mgte injectors, bigport and smallport injectors
    By Rich_86 in forum Car Parts For Sale
    Last Post: 13th March 2008, 09:22 PM
  5. SARD Injectors 534cc Part number 63501 (4 Injectors)
    By gasit in forum Car Parts For Sale
    Last Post: 13th December 2007, 10:41 PM
