er...no...
if its leaking, and the gasket is in good condition, its not tight enough...
its only like a m4 bolt if that, dont swing off it.
firm but not tight...as they say
Just wondering if the 16v Bigport 4AGE Tappet Cover has a torque setting on the bolts?
er...no...
Not leaking, Just wanted to take it off and Paint it that's all lol, Thanks for the quick response.
No torque setting as such. As a M6 nut/stud, the default setting is about 4 - 8 ft.lb depending on strength. But on a cam cover, only enough to make the seals squish a bit.
When I had an apprentice, I used to clamp a few 6mm bolts tight in the vice. I would then give them a 10mm socket and ratchet, and tell them to turn the heads till they snapped off. So then you know, on a real car they should not be as tight.
