Results 1 to 10 of 15
Thread: EPAS for AE86
    Nov 2011
    Ray
    Qld
    Manunda
    Default EPAS for AE86
    I just fitted EPAS (Electric Power Assist Steering) to my car. It works very well. Here is some pictures...
    Veteran Rice86's Avatar
    Richard
    Liverpool
    i personally would never do this even if i was in the need of power steering, but good work i say
    how does this compare to standard power steering
    sorry what car is this on and what is the car used for? looks like a track hack car by the pictures
    dose
    Looks good, keen to know the details as traditional power steering is a horse power thief...
    Gunner
    Would love to see a build thread from Ray. Would love to see what is powering this, especially considering the amount of 1000hp+ works of art come out of Ray Hall Turbocharging.
    Nov 2011
    Ray
    Qld
    Manunda
    The AE86 is a rally car. EPAS has a lot of advantages over normal power steering. You do not need a power steering pump, oil lines and power steering rack. Also the EPAS only draws a maximum of 8 amps of power. Most steering moments draw less then 4 amps. This is why most new cars have EPAS now. Also if your are not tuning the wheel it draws nothing, unlike oil power steering.
    The EPAS is dead silent, and very nice to steer.
    The reason for fitting it other then the mentioned advantages is you can fit a quick rack and still have power steering. Something not possible with normal power steering.
    Ray.
    Nov 2011
    Ray
    Qld
    Manunda
    Yes uses ever little power, and far less complicated.
    Ray.
    Nov 2011
    Ray
    Qld
    Manunda
    I have pictures of the step by step process to fit the EPAS to the AE86 steering column. I will get them together and post them.
    Ray.
    Definately keen to do this for my track car(s)...
    Veteran slide86's Avatar
    Huw
    Hills
    wow i love the engineering and "oh heres a problem, so im just going to make a solution for it now" mentality.
    Nov 2011
    Ray
    Qld
    Manunda
    Here are pictures showing most of the steps to fit the EPAS to the AE86 steering column.
