BUMP, price drop $5000 o.n.o.
Item: 1988 AE82 hatch
Website: gumtree
Item Condition: Good for a 24yr old car just resprayed
Reason for Selling: need car with a/c & p/s
Price and Payment Conditions: $5500 cash
Extra Info:
It has a AE101 4agze engine with abv mod running standard boost (gets up to 10psi) roughly 90,000 km's but no proof
Standard 4age box (2nd and 3rd worn)
AE101 standard top mount
Extractors (unknown brand)
2 1/2 inch pipe from extractors to rear muffler with it being reduced to 2 1/4 for back pressure and noise.
In the last 5000 km's i have changed or replaced:
- Supercharger oil
- Gearbox oil
- Coolant
- Thermostat
- Timing belt
- Cam seals
- Front crank seal
- Spark plugs
- Both drive belts
- Clutch slave and master cylinders with new clutch fluid
- Front and rear pads (bendix) with front disc machined
- Front and rear caliper seals (painted red when done)
- Brake fluid changed
- Injectors ultrasonic cleaned, flow tested and new filter put on (standard 4agze injectors)
- RX7 fuel pump
- Front headlights and corner lights (aftermarket, still have the original but seen better days)
- Aluminum intake pipe with stainless pod
- Engine oil with genuine filter replaced about 500 km's ago.
Things that can be taken out to drop the price or will be included in the sale if price is right
- Drift digital boost gauge
- Nardi steering wheel (has autotechnica horn button, original one broken)
- Jensen DVD touch screen player
- TRD gear knob
Things that are not 100%
- Front seat needs to foam reattached underneath as it has collapsed (have a piece of wood in there atm lol)
- Handbrake cables need adjusting as it goes up all the way for it to work
- Needs a new windscreen due to previous owners not changing the wiper blades when worn out and has scratched the s#!t out of it.
- Tints are shocking
- New tyres, atm they are still legal but only just, nearly to the wear markers.
- Gearbox has worn 2nd & 3rd syncros (have used genuine toyota box oil and has helped abit)
- Needs new top dash bit as the one on there has all the clips broken as usual.
- Fuel gauge only works when it gets to have a tank then works properly, the fuel light comes on when it is meant to though (95% sure its the fuel sender unit)
- Unknown suspension as i have never touched it since ive owned it.
- No power steering or air conditioning.
Car is engineered and reported with NSW RTA (condition on rego label)
Also car is mod plated in QLD where the car was originally from.
Rego till the 03/03/13
Comes with original twincam steering wheel and airbox.
Pictures:
Contact Details: PM me or here call / text 0433742995
bump, price drop $4700 o.n.o.
Bump... Price drop $4500
