sold pending
Up for sale aus spec AE82 blacktop 20v
330xxx km on body but could be less . . . has the twin cam cluster
around 80 xxx km on engine
conversion was done in 2005, modplated
Has buddy club P1 17" wheels, one has had a gutter hit, repairable. Tyres are sweet, plenty of tread
clutch was done about 1 year ago
has twin cam rear disc's, fuel tank, and dash
front rotor's are cross drilled and slotted
has new koni's and std height king springs in the rear, all new bushes in the rear.
front suspension looks stock but is A1
new brake hoses all round
5 speed is sweet
alloy radiator with thermo fan on front
new battery
Engine wise it has a stock computer
I have made a full mandrel bent 2 1/4 exhaust with 3 resonators and 1 lukey muffler on the back, 2 months old.
modified the standard airbox to fit trumpets
comes with new uni filters if you wanted to ditch the airbox
when i bought this not even 6 months ago i compression tested it and it come up 200psi on all 4 cylinders and would have no reason to think i would have changed.
I installed a new stereo and made a custom rear parcel shelf with 4 new 6 x 9's
The bad
rear wheel arch's had rust, was repaired but a rush job and was only rattle canned to pass rego
Thermo fan is constantly on, guessing faulty thermo switch
oil filler cap is cheap aftermarket rubbish and doesnt seal 100%, could do with a genuine one
has no front carpet
drivers window doesnt go up straight, 2 handed job suspect missing 1 positioning bolt
fuel guage play up a bit but still has working fuel warning light
Its registered, comes with a few months rego left if you can provide a roadworthy
Overall car is not the prettiest thing to look at but great mechanically, get's just over 500ks to a tank
$3000
THE EVOROLLA
none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
sold pending
THE EVOROLLA
Back up for sale after being totally fucked around
THE EVOROLLA
SOLD . . . .
THE EVOROLLA
