what u do with the ols turbo setup?
silly me.
get much axle tramp with your rear leaf setup?
good job.
Awesome! makes me want to go work on mine but its raining outside
So what diff is taking the power of the sr20det atm? still the hilux rear?
sick chicks!
crackett: no extensive plans for the engine at the time being, i just replaced 2 pistons that i broke the ring lands offhave fitted a oil cooler and bigger alloy raditor, i think it makes enough power for now (t28 on 15psi)
if i brake another piston i prob just chuck some forgies, rods, cams and springs in there and a aftermarket computer and be done with it
ae70 - dont have any problems with axel tramp, used to but the half upsidedown leaf sorted it out
wanabdrifta - just in the pile with the rest of the stuff (its a masssive pile)
Jdm070 - yep still the G series hilux, locked up, starting to wear the splines on the axels now tho
cheers for the comments guys, i'll try and do a update this week if i get home before dark one night
bit of a update... made a new actuator, down to 7psi now and damn i miss the power but i think it will make me a better driver, had to put a ugly vent in bonnet for oil cooler (i will change this later when i have time) and 3" pipe welded into inner guard for air flow
brought some new goodies for it but wont put them in till after the next track day, some jun 264 cams and springs, new fuel pump(will be adding more baffels to tank at same time) some subaru 440cc injectors and sard reg, so just looking for a new afm and then i'll chuck it all in and get a tune, hoping for ~200kw at wheels
my g/box isn't liking me much i think 4th gear is going to blow soon, it makes some crazy noises
what windows are in the back i have a pano, are the windows just wagon ones?
just the standard 2dr jdm/nz wagon windows
that BBS mesh is so winn
fuck yeah,this is sweet!!
Sam Q is making up traction rod's for corolla leaf springs atm...just a thought,might be worth looking at??
edit,Love the Starlet too!!! I want one hard!
Josh
43ger
Performance
SINCE 2008
