Shotgun steering arms![]()
Need to get rid of as much as i can before i go overseas!!
If you need/want a better pic of something, feel free to ask
Prices are negotiable. If you don't like a price shoot me a pm or an offer. Can work out deals for multiple items
All items are located in VIC. I work during post office opening hours so I prefer to keep it local, but posting isn't completely out of the question, especially for small items.
Contact:
Dario 0432215963
1. 4AGE bigport map sensor $40
normal working order but no plug
2. 4AGE Flywheel 200mm WAS $50 NOW $40!!
surface rust would suggest machining, otherwise no issue
3. AE86 steering arms - Manual rack $50 SOLD!
good nick, unmunted
4. 8mm slip on spacers $5 (free if u grab something else) SOLD!
pretty much new.. i bolted my wheels up with them and unbolted instantly...
5. XT130 LCA's $60
good condition half refurbished..however... i was given the wrong ball joints (slightly larger) and they were pressed in widening the hole slightly... so to use these you will have to run a larger diameter base ball joint.. one is still in there (new, worth $40 just for the ball joint!) the other the suspension place lost. I'm literally losing money on these..
6. S13 CA18 calipers WAS $50 NOW!! $30
suit rebuild
7. 4AGE 16v crank pulley WAS $15 NOW!! $10
normal
8. 4AC water pump pulley WAS $10 NOW!! $5
normal
9. 4AGE starter motor WAS $40 NOW!! $25
pretty sure this worked. me personally id rebuild it anyway. one of the site sponsors offers this service
10. AE86 tie rod ends $10pr
pretty average but they are straight.. the ball joints most likely arent too great
11. 4AGE 16v water pump x2 WAS $15ea NOW!! $10ea
one of these was in the car working and i have no idea which. the other should be working but havent tested.. average condition
12. 4AGE 16v TVIS plate WAS $20 NOW! $15
was in working order when removed, just a bit dirty
13. 4AGE 16v bigport cams $50
14. 4AGE 16v bigport cam gears $20pr
15. 4AGE 16v bigport 3-rib block $80 SOLD!
suits rebuild.. pretty sure was a spun bearing. includes everything
(block,pistons,rods,crank,sump,oil pump...still assembled)
16. 4AGE 16v RWD factory headers $65 SOLD!
good condition with all shields included
17. 3" Cannon WAS $40 NOW!! $30
does the job.. actually didn't sound bad. pm for video link
only removed it because it was a bit loud and i wanted twin pipes
18. 4AGE 16v smallport head $150 SOLD!
includes valve train, no cams/gears or covers...looks good. journals and caps look good. the engine had a blown head gasket so its a bit dirty on the bottom but with a nice clean it should be fine.
19. 4AGE 16v bigport head $150 PRICE DROP!! NOW $100
includes valve train, no cams/gears or covers, missing one bucket and one cam cover bolt. suit rebuild
pm'd
added bigport head to EOI
Steering arms
Bigport head
Bigport cams
Bigport cam gears
Smallport head
all pending
keep em coming guys... don't be scared to make offers. negotiable on most
headers pending
Updated first post
price drop on bigport head!
Items pending:
smallport head
bigport cams
bigport gears
RWD headers
headers sold
price drop on the s13 calipers!
smallport head sold
price drops on several items!!
Got alternator?
