Results 1 to 9 of 9
Thread: diesel anyone
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    Default diesel anyone
    so the other day i put diesel in my car instead of petrol
    no just kiddin i just wanna ask if anyone knows the difference in rebuilding a diesel motor over a petrol why its so much more expensive than a petrol motor
    a rebuild kit for a diesel is about $900
    i no its way out o left field but im sure some one knows and i dont really want to sign up to a 4x4 site just to ask one question
    Dave
    wanna be a lil more specific?
    a "rebuild kit" for a petrol engine will be about the same. what do you get in your "rebuild kit"
    a piston engine is a piston engine, they all work the same. just turns out diesels do the same thing slightly differently.
    underwood
    qld
    jimboomba
    well i have googled it as best i can, best figure i can get for a stock rebuild on a 2.4 diesel is 8k and i wanna no why it would cost that, as you said a piston engine is a piston engine
    4 X PISTONS, 1 X MAIN BEARING SET,1 X THRUST BEARING SET,1 X CONROD BEARING SET,1 X FULL GASKET & SEAL SET,4 X PIN BUSHES,1 X GRADED HEAD GASKET,1 X SET RINGS,1 X CAM BEARING SET,1 X BONUS FITMENT PACK,1 X SPEC SHEET.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Just to specify and rebuild is not cheap for a motor, depending on whats wrong with it.. My 4age cost just under 6.5k to rebuild, In and out of the car from my mechanic, Thats With everything Fresh, Practically a new motor lol..
    underwood
    qld
    jimboomba
    i was actually thinking that last night when i was making this thread im good mates with my machanic and i have never paid labour and i pay cost price for parts and i normally do as much as i can myself anyway. so i guess if you just dropped your car off and picked it back up again finished i can see how it would add up quickly hhmmm
    Dave
    labour = expensive
    i got quotes on 4age parts for rebuild, it went something like this
    new pistons ACL with rings: 300
    main bearings acl: 150 ish
    conrod bearings: 100 ish
    full gasket kit (stanrdard): 250ish
    so thats like 800, not far off your 900..
    then the actual labour, there are to many variables to consider.
    does it need a crank grind? how bad is the head? does it need "Straightening" (essentially machining everything)? does it have corosion and need welding?
    for reference i did a head gasket job on my mates BP mazda, and the head was rooted. was rusted and needed straightening. $1000 dollars in labor later and we had it back (just the head wrapped in plastic)
    and i got a quote to rebuild the bottem end of 4age. and the labor alone was around 1200$ for JUST the bottom end assembly/machining (no parts included) this took into account worse case scenario including overbore and crank re grind.
    so thats 900 + 1200 + 1000 aprox for "standard rebuild" assuming that you are able to put the head back onto the block and put it all back together.
    if you want a drive in drive out style thing...its a crapload more....
    now i would say that these prices would be fairly standard across of "normal" engines. if you start talking about fancy engines like VTEC and forged stuff (sounds dodgy but the best example i can give) then the prices just sky rocket...
    now in terms of diesel, maybe there is something special about the pistons for the high compression, so we'll assume that the pistons are say...600 (add 300 to guesstimated price)
    so thats about 3500...
    so in conclusion, i have no conclusion, your gonna have to ring up a machinist and a parts supplier (usually the machinist too) and get some proper prices
    6.5k seems alot for a drive in drive out rebuild of a 4age though.....i should be a mechanic and charge ppl 3000 to pull a 4age out of a car.....
    damn i fogot a few things....
    oil pump: 200
    water pump: 200 (guess?)
    cam belt and guide bearing: 100
    crank cam belt gear: 60?
    harmonic balancer: 150?
    it just keeps going up and up. but like i said it depends what needs doing...
    Jonathan
    It is worth shopping around for motors. There are millions more diesel HiLuxs in Australia and south-east asia than there are 4A-GEs. Lots of options. You can get brand new re-manufactured motors on ebay, maybe built in Thialand or someplace. Lots on non-genuine parts are made all over asia.
    Give your local Toyota dealer a try, you never know. My local dealership had a clearance sale of 5L long motors a couple of years ago. $3000 for a complete 5L from memory, no manifolds.
    Veteran biggo's Avatar
    Nick
    Noosa
    THat is cheap Jonny!
    Here i can get you a remanufactured 1HZFE long motor (no manifolds) for $14890. I know i saw the toyota trade specials today! Imagine if you had to pay retail?
    But really, when you pay an engine shop to rebuild a motor, you are pretty much walking/driving away with a brand fucking new motor. but you would have to be stupid/dumb/love your car to do that cos Hyandai sell new getz for what $13000, And you get a brand new shell for that motor.
    Me, i just spent $1k on my bottom end
    Jordan
    Sunshine Coast
    Mind you it's not your average rebuild lol.. Full forged pistons/rods, $1000 port and polish job, HKS Cams And cam gears, All new water pump/oil pump etc.. etc , I didn't really get charged for labour as im pretty good mates with my mechanic!
  1. 96 LWB diesel Hiace
    By juzzo8 in forum Cars for Sale (Not Toyotas)
    Last Post: 22nd August 2010, 07:24 PM
  2. Diesel power... Yes or No?
    By letsgohunting in forum General Topics (No Technical Questions)
    Last Post: 6th February 2009, 02:51 PM
  3. 2L, 3L diesel conversion
    By drftr86 in forum Technical - Questions
    Last Post: 20th July 2007, 06:46 PM
  4. diesel in your oil change
    By damo46 in forum Technical - Questions
    Last Post: 14th January 2006, 12:48 AM
