Results 11 to 20 of 29
Thread: Twisty's Ae86 sprinter 4age 20v
  1. #11
    Senior Member bradae85's Avatar
    Nov 2010
    Brad
    Canterbury
    Papanui
    New Zealand
    Looks good with the alloy rad and new hoses too.
  2. #12
    Sep 2012
    Tristan
    Koongal
    Hey guys
    I'm starting to bang my head against the wall about wiring up a "vehicle speed sensor" for my 20v, its not connected - only revs to 7200rpm instead the claimed 8200
    i've looked through so many threads trying to find out what i need...i've connected from the reed switch in the back of the cluster to the ecu but no luck - still 7200
    i've tryed wiring a flasher unit in just to see if this would help nothing..and finding a wiring diagram to suit is proving difficult. i have a 26pin 16pin and 12 pin.
    I'm not even sure what kind of reference the ecu wants to see? the reed switch was putting out a frequency but still didn't work, unless i have the wiring in the wrong pin?
    i also boughtt a 555 timer circuit with a 'astable operation' but it got broken whilst at work ...but we aren't going to go there, so i didn't get to try it out.
    thanks tristan
  3. #13
    Wire up your check engine light and run off the codes... If there is another issue, it will also not rev out, not always the check engine light.
    Is this the diagram you are after?
  4. #14
    Sep 2012
    Tristan
    Koongal
    Thanks brad! did not see your latest comment until now.
    Matt, this is the wiring diagram i went off today...
    i hooked up a flasher unit to give the ecu a dc wave the pin labelled SPD and when i got to about 4000 rpm it back fired...and had a noticeable different rev up tone though when it was connected up.
    i will try to figure out how to connect the engine check light up... i got about 7 days until i want it registered and i thought i had this issue sorted out :/
  5. #15
    Check engine light is easy... ignition power to one side of a globe, and the W pin off the ecu is the earth. Any 12v globe is good but the one in the dash is best.
  6. #16
    Sep 2012
    Tristan
    Koongal
    Thank you matt, good info is good i shall do this
  7. #17
    Aug 2010
    Sutho Shire
    with tyres go a 195 50 15 that will be good on 7's,8's or 9's
  8. #18
    Sep 2012
    Tristan
    Koongal
    Roger for no engine check light, i got a park light bulb and no check light on....silly me spent ages trying to figure out which wire is for the engine check light for the cluster but it doesn't have one lol.
    i was wondering can i bridge out some wires to figure out if any codes are stored? or does this model ecu have a diagnostic plug>?
  9. #19
    Sep 2012
    Tristan
    Koongal
    i think i will go with these too, cheap to purchase aswell
  10. #20
    Sep 2012
    Tristan
    Koongal
    Hey all, after some more research into my "vehicle speed sensor" problem
    i would like too ask two things
    Has anyone just connected the 4 pulse / rev output from the back of the tacho to a standard 20v ecu and it clear the whole rev limit problem?? my doesn't seem tooo ( i've also taken for a drive to get some pulsing coming from cluster so the ecu doesn't think i'm free reving)
    2ndly i am reading about Apexi RSM which looks like it could fool my Ecu to help with rev limit and speed cut?
    Could any one please varify these and there experiences with the vehicle speed sensor issue?
  1. suitable gearbox/diff upgrades for ADM sprinter running 4AGE 20V???
    By schmykel in forum Technical - Questions
    Last Post: 20th July 2010, 11:40 PM
  2. 20V Toyota Sprinter AE86 Gold Coast
    By alexthem0nk in forum Cars for Sale (Toyota Only)
    Last Post: 2nd September 2009, 11:45 AM
  3. toyota sprinter ae86 20v now updated
    By callaghan86 in forum Cars for Sale (Toyota Only)
    Last Post: 17th August 2008, 11:56 AM
