Page 10 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 91 to 100 of 166
Thread: Track\Daily challenge
  1. #91
    Senior Member Noddy's Avatar
    Apr 2011
    Stuart
    Qld
    Warwick
    Pistions have arived and test fitted checking for deck ht. and clearances. With a 50 thou head gasket compression is 13.8:1.
    Jungle juice is well in order.
    Sent from my SM-G930F using Tapatalk
  2. #92
    Apr 2011
    Stuart
    Qld
    Warwick
    Love a good short skirt.
  3. #93
    Apr 2011
    Stuart
    Qld
    Warwick
    Progress.
  4. #94
    Apr 2011
    Stuart
    Qld
    Warwick
    Painted the engine bay today. Just to freshen it up.
  5. #95
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Hi
    Nice piece of work
    What set up are you using in the carbs
    Venturi, air & fuel correctors.
    Sent from my iPhone using Tapatalk
  6. #96
    Veteran Konakid's Avatar
    Henry
    Eastern
    Holy compression batman. Should make very good numbers on some United E85!
  7. #97
    Apr 2011
    Stuart
    Qld
    Warwick
    I was trying to find the details of what we put in them... I'll have a chatt to my carb man and get bact to you.
  8. #98
    Apr 2011
    Stuart
    Qld
    Warwick
    Well, no.
    Comp came in slightly lower, 13.6:1
    Most dedicated race fuels are going to be fine. The ELF fuel used in F3 cars is a good example. Only $8.38/L last time I looked!
    I'm going to try the BP race fuel first.
  9. #99
    Apr 2011
    Stuart
    Qld
    Warwick
    What a long process the flywheel was. Ended up having one made localy, 3.6 kg. 200mm plate and an extra clampy plate. Just neede a custom alignment tool. Pretty happy with the progress today.
  10. #100
    Apr 2011
    Stuart
    Qld
    Warwick
    So, the close ratio albins box got fitted up and went to fit the tail shaft... box has a 20 spline shaft, 22 in the tail shaft
    I decided to swap the main shaft out and have found some differences in the t50 boxes. Pic to come.
  1. The make do AE71 daily, turn tidy track slut in the making.
    By ktm372 in forum KE70 / AE71 Owners Forums
    Last Post: 2nd January 2012, 04:02 PM
  2. AE92 daily/track
    By AE092 in forum Other Toyotas
    Last Post: 26th February 2010, 04:02 AM
  3. AJPS - AE71 - daily, turned track slider
    By slidin 86 in forum KE70 / AE71 Owners Forums
    Last Post: 26th January 2008, 06:03 PM
  4. scotts daily soon to be on track
    By scott_20valvehachi in forum AE86 Owners Forums
    Last Post: 3rd September 2007, 01:34 AM
