Page 11 of 17 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 101 to 110 of 166
Thread: Track\Daily challenge
  1. #101
    Senior Member Noddy's Avatar
    Apr 2011
    Stuart
    Qld
    Warwick
    The 2 shafts side by side. 20 on the right, 22 on the left. Biggest change is the 2nd gear land and the nut retainer at the 5th gear end on the 20. The 22 has a cerclip arrangement. Albins do have the set in stock and have both 2nd gears as well. That said, should i want a new box/set I need to send send the lay shaft for modification and $4300... I wonder what the alternative 2nd gear is worth?
    Sent from my SM-G930F using Tapatalk
  2. #102
    Apr 2011
    Stuart
    Qld
    Warwick
    Update on the gear situation.
    Going with the 20 spline box because it is $700 for the 1/2 of the 2nd gear set that i need. Using a S1 T18 front section of the tail shaft will marry up to the AE86 tail section. The uni is slightly smaller but I think it will be ok.
    Waiting on the MRP 4.89 diff gears to land before fitting the new drive line. It will be in for Noosa Hill Climb but for now I'm just going to run my old std box and 4.3 diff.
    The fuel system.
    There was superfine red crap, talcum powder like in texture in the sump and carbs. I pulled the fuel tank out today and! HOLY COW. Silt to the max. There was about 12l of fuel in there which I used to flush it a couple of times. I've since removed it and given it a good pressure clean and replaced some old hoses.
    All nice and clean ready for some fresh BP 100 race fuel.
  3. #103
    Apr 2011
    Stuart
    Qld
    Warwick
    Got my little project started yesterday. 1 oil leak out of the oil temp sensor and 1 water. Both relatively easy fixes. The fuel pressure reg was totaly another story. I had to source a new 1 and set it up to 3.5 psi.
    Once started I needed to get the speed screws on the webbers set properly and run for a while getting the temp up and set the timing then I left it to cool out for 6 hrs and did a cold start test. Webbers ser up properly are awesome.
  4. #104
    Apr 2011
    Stuart
    Qld
    Warwick
    It was nice to get the car back on the track today. Running a motor in can always be a bit of a edgy time. Today it didn't help that the water temp gauge wanted to play solly buggers. All in all it ran perfectly and I will continue with the run program tomorrow, hopefully it will round me old sparing partner up tomorrow. Silly 7A hiding in that 1.
  5. #105
    Apr 2011
    Stuart
    Qld
    Warwick
    Livery idea.
    I want to to give the old girl a period correct but generic livery. Im liking this one at the moment.
    Thoughts?
    Ideas?
  6. #106
    Oldschool Member Buddy's Avatar
    Mar 2006
    Stewart
    That looks mad!!
  7. #107
    Apr 2011
    Stuart
    Qld
    Warwick
    Slowly coming together
  8. #108
    Veteran Konakid's Avatar
    Henry
    Eastern
    lookin noice
  9. #109
    Jun 2011
    bazz
    nsw
    sydney
    Nice cars
  10. #110
    Apr 2011
    Stuart
    Qld
    Warwick
    The Rx2 is 1 of the MPP fleet group Nc racers. Great bunch of mates.
  1. The make do AE71 daily, turn tidy track slut in the making.
    By ktm372 in forum KE70 / AE71 Owners Forums
    Last Post: 2nd January 2012, 04:02 PM
  2. AE92 daily/track
    By AE092 in forum Other Toyotas
    Last Post: 26th February 2010, 04:02 AM
  3. AJPS - AE71 - daily, turned track slider
    By slidin 86 in forum KE70 / AE71 Owners Forums
    Last Post: 26th January 2008, 06:03 PM
  4. scotts daily soon to be on track
    By scott_20valvehachi in forum AE86 Owners Forums
    Last Post: 3rd September 2007, 01:34 AM
