Page 12 of 17 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 111 to 120 of 166
Thread: Track\Daily challenge
  1. #111
    Senior Member Noddy's Avatar
    Apr 2011
    Stuart
    Qld
    Warwick
    I've been a bit distracted for the last few weeks getting my students to their race meeting at lakeside. They did pretty well
    Sent from my SM-G930F using Tapatalk
  2. #112
    Apr 2011
    Stuart
    Qld
    Warwick
    Racing at noosa hillclimb. Won my class.
  3. #113
    Veteran Konakid's Avatar
    Henry
    Eastern
    So good. What school is that? Like a technical/race car engineering college?
  4. #114
    Apr 2011
    Stuart
    Qld
    Warwick
    Just a high school in rural QLD. Dalby SHS.
    We have a good Trade Training Center that we run here and the cars are part of our signature trade program. There are about 15 schools around southeast QLD running the Formula Student program as part of their own curriculums.
  5. #115
    Apr 2011
    Stuart
    Qld
    Warwick
    Took the Levin out to the sponsors and family ride day. Good day was had by all. It was certainly busy out on track with around 100 or more cars in attendance.
  6. #116
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Nice piece of work
    Any idea what carb set up you have
    Chokes(venturi), fuel jet , air corrector and the timing ignition top end advance.
    Sent from my iPhone using Tapatalk
  7. #117
    Apr 2011
    Stuart
    Qld
    Warwick
    Not quite sure on the choke. 36 or 38.
    F16 emulsion tube, 199 air and 140 mains.
    Advance is 32°
  8. #118
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Thanks for the info
    Can wait to see new engine numbers and the car running with the new gearbox.
    Good stuff!!
  9. #119
    Apr 2011
    Stuart
    Qld
    Warwick
    So... today I finally got to the Dyno. It showed that literally no head work was carried out in the rebuild. It also highlighted the lightend rotating assembly by building up to peak power earlier and holding it for longer. Torque was up and earlier too.
    The lowest power run was 158 rwhp and peak was 165. At 9200 the hp was still up in the mid 150 mark but torque ha seriously diminished.
    The 165 run. Up to 9000ish.
  10. #120
    Apr 2011
    Stuart
    Qld
    Warwick
    It has been a busy family year and not a lot of racing unfortunately. There has been some developmet work (a new adj panhard for 1) and found a couple of gremlins. 1 easilt fixed, the other will take some time and is often the case... a whack of $$$
    Back on the dyno I noticed the passenger rear wheel had quite the wiggle! The axel was bent. I found an offroad suspension and driveline specialist who were awesome to deal with and did a superb job fixing it.
    While it was appart I took the opportunity to put the new MRP diff gears in, 4.89:1 and swap over to the Albins close ratio 1,2,3 box. It worked beautifully on the track at Morgan Park for a test day before taking it Leyburn historics. The ratios were not so perfect there. The video is proof to that but still good enough to win under 2l special interest class and 43rd out of 211ish entries.
    Next was a lakeside test a few weeks ago... on the third lap, going into the kink, the loud pedal went dead. The turbo xr6 and R33 were no longer holding me up. There was no restarting the 4a. A compression test showed little if and compression in cyl 2 or 3. This is the second gremlin.
    Expecting to fing a blown gasket from 2-3 i found a good intact head gasket and a damaged bore? There is heavy scoring and signs the ring lands are damaged. I have some theories but next week I will pull the bottom end out and strip it down to get a more detaild look at the damage.
  1. The make do AE71 daily, turn tidy track slut in the making.
    By ktm372 in forum KE70 / AE71 Owners Forums
    Last Post: 2nd January 2012, 04:02 PM
  2. AE92 daily/track
    By AE092 in forum Other Toyotas
    Last Post: 26th February 2010, 04:02 AM
  3. AJPS - AE71 - daily, turned track slider
    By slidin 86 in forum KE70 / AE71 Owners Forums
    Last Post: 26th January 2008, 06:03 PM
  4. scotts daily soon to be on track
    By scott_20valvehachi in forum AE86 Owners Forums
    Last Post: 3rd September 2007, 01:34 AM
