Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: 4age overheating
    Adan
    Oxley Park
    im pretty sure theyre the same.
    And dont get a low temp one, just get a normal 82 degree one. No point hiding the other issues by using a lower temp thermostat.
    go genuine toyota thermostat... You can't beat them..
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    "tridon" does a switch, that fits where your coldstart injector switch is, if you want something clean, i recommend it (i use one), having using with a davies craig switch at the moment(cant get the probe wire to seal in the hose)
    have had issues with tridon radiator caps not seal constantly leaking pressure, my friend(another member on here) went back to his old cap and My 4a Cooked before i sorted the issue
    ryan
    Sorted the over heating issues, fan was blowing the wrong way but now its alway cold so will be adding a temp gauge and a temperature switch to turn the fan off and on. hopefully should sort things.
    Michael
    Crimebrook 2749
    hahahaha first test i do whenever installing any fans, throw a piece of paper, into the front bar
  1. Overheating Smallport 4age AE71- Headgasket?
    By pauliee in forum Technical - Questions
    Last Post: 28th September 2012, 02:01 AM
  2. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
  3. 4AGE overheating problem
    By shinny in forum Technical - Questions
    Last Post: 25th November 2007, 12:31 AM
  4. How hot does your 4age need to get and for how long till its OVERHEATING?
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 24th November 2007, 12:56 PM
  5. Engine Overheating
    By fozz in forum Technical - Questions
    Last Post: 17th September 2007, 02:03 PM
