Diff's getting powder coated
and
Rack now sits right up against Xmember, boxed in with 3mm plate
starting to push the whole rego thing
and
hold it out to fit hoist
you end you getting that panhard rod off the diff?
nah we packed up and went home, was stuffed
ill try tomoz night, pending how putting the other hoist goes
Now to wait for it to come from the US
pretty good for how cheap it was, need to be cut up though hahahaha
also, will be running an EVO7 ECU, engine loom, Cluster, fan controls, launch control, may even duel map, doubt it will ever go on 98 though
Wow mate nice work!!!
Subscribing
diffs back from being powder coated satin black looks mint
Now to fuck my tunnel off
Pending price my boss comes up with (doubt it will be cheap enough) or from Yahoo Japan, i will Getting Evo7 cluster, and basically a front cut loom, to run everything thing off a evo 7 ecu (fans, boost, temps etcetc), will look into what would have to be done to convert the hilux box speedo sender to work with the evo 7 cluster and ECU, as i will be running launch control etcetc(under 5km's it will use launch control)
shifter position doesnt look to bad with the R155 and the 4g, considering how far back i sit anyways it should be sweet, went to sit box and engine in thurs night, and couldnt find an angle grinder(noramlly everywhere)
