Results 1 to 10 of 15
Thread: Rear Coilover? How is it done
    Default Rear Coilover? How is it done
    Hey,
    I want some adjustability in the height of my hachi (just like the front coilovers)
    this is due to having a punishingly low driveway, so i want to be able to adjust for daily use and track use.
    how can you get adjustable height in the rear? do i have any other options apart from rear coilovers?
    of not how is the conversion done?
    User fantapants's Avatar
    Pat
    bc seems to be the flavour of the month
    though seriously, the amount of fucking around involved in changing heights once you have them sorted is AWFUL. Plenty of guys skid just fine with legally acceptable hieghts, check robos notch man, that boy is sliding a 4x4
    And well frankly a well sorted higher car will handle better than a grass cutter. Just run it at the hieght you can and make the best of it. Or be like me and run it low and grind the hell out of the exhaust everytime
    06/07/2011
    Pat
    also forgot ol man gilly's effort, well made setup treditional coilover, not the split unit like bc so setting should be easier.
    But yeah, coilovers are great for wank and for allowing cornerweighting and not a lot else
    i got them for the wank
    06/07/2011
    well i can lower the back about 15mm at the moment without hitting
    so now i guess i have to find out which springs give me that height...... which is a pain in itself....
    and here we have the problem.....
    here is the height
    and here is the clearance.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    get some 15's on yah =], best trick ive learnt, plus they can look sick
    dose
    Jun 2009
    Grant
    California
    San Jose
    USA
    If you upgrade to 15's or 14's, you can probably find a decent tire size (205/50/15, 195/50/15) that might have a taller overall diameter than what you have now.
    The gap between the wheels wells will look smaller to, while giving you better ground clearance.
    Keep in mind, every time you raise or lower the suspension, the toe will need to be re-adjusted. Even if you do the rear, the caster changes slightly, as well at the toe. Changing ride height isn't as convenient as we'd like..
    Pat
    fuck that lower the crap out of it... then chock the gutter with wood planks the smooth off the transfer... make sure you dont limit draininage and explain to your neighbours why u are doing it, and no one should have a problem
    or if you can fab, make something less conspicuous
    06/07/2011
    oh and for the record, i am going for rota grids (16x8) in a month, but they will have the same rolling diameter as the stock rims......
    i might try to chock the gutter, get a little arch going so water goes under and i go over.
    Richard
    Liverpool
    Escalator FTW
    dose
  1. Coilover Sale - AE86 Front + Rear Springs & Shocks - S13 Rear
    By Skid_KE70 in forum Car Parts For Sale
    Last Post: 10th October 2012, 03:07 PM
  2. adjusting BC rear coilover
    By evil86 in forum Technical - Questions
    Last Post: 8th January 2011, 02:52 AM
  3. Rear coilover options?
    By GOODY in forum Technical - Questions
    Last Post: 23rd August 2010, 12:15 AM
  4. Rear coilover mounts
    By biGtai in forum Technical - Questions
    Last Post: 23rd August 2006, 09:03 PM
  5. Rear coilover setup
    By sprinterboy in forum Technical - Questions
    Last Post: 6th December 2005, 08:20 PM
