Page 3 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 146
Thread: G Series & F Series Diff Disc Brake Solutions
  1. #21
    Jake
    Northgate
    And a picture of my setup.
Name:	2012-10-23 11.23.22.jpg
  2. #22
    West
    So your happy with 5 stud then?
    I like the set-ups above but its still more brake than I need in my application.
    Im going to do a single caliper with a handbrake, looking for a rotor no bigger than maybe 280mm. Definitely must be vented.
    I really dont want to have to modify rotors to fit, so I may look at turning down the ends of the axles to suit some particular rotor.
    For mass vs features I think Wilwood caliper with a built in handbrake could be lighter and cheaper than an oem spec caliper, especially by the time you buy the Nissan calipers, pads, and rekit them. To my thinking it makes the Wilwoods at around $300 a pair seem very good value for what you end up with. Being an F series user I am a little bit conscious of how much unsprung weight I am adding vs the durability of the rear end. I only wanted to put the minimum sized diff into the car that I thought I could reliably use to keep it as light as possible, so adding 2 large sets of oem calipers and a slightly larger rotor than I desire is not quite where I want to be.
    I can see how its very good for the track though.
  3. #23
    Jake
    Northgate
    Yeah doesn't really bother me just a bit hard finding 15" wheels in 5 stud, but already have 4 pairs so that's enough for now. The adapters cost $60, rotors $100 and remanufactured calipers were $150 so for the price I love it haha.
  4. #24
    Senior Member Skid_KE70's Avatar
    Daimon
    Tasmania
    Launceston
    Here we go:
    8x 8.8 Grade Bolts
    8x 18mm Polished Alloy Spacers
    16x Washers (Zinc Coated)
    2x 8mm Mild Steel Brackets (Zinc Coated)
    ill upload some pictures of these fitted later on.
    ---- Fryin Fifth Represent ----
  5. #25
    Gone
    Joel
    Picton
    Thats odd... how do you get that over the Axle housing?
    housing require mods to fit?
  6. #26
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    axle out
  7. #27
    Junior Member Bigwill's Avatar
    Aug 2010
    William
    Alexandra hills
    I'm after a disc rear end for my levin. What's a good LSD option?
  8. #28
    Gone
    Joel
    Picton
    For what diff?
    Right... so this mounts on the outside.
    understand now. Ta.
  9. #29
    Daimon
    Tasmania
    Launceston
    The cutout is just big enough to slip over the smallest part of the diff housing, it steps up end the end of the diff tubes where the axle bolts, these brackets bolt on the side closest to the diff centre (not the outside) so you do not need to remove the axle. No modification required. I'll have pictures up tomorrow of these fitted, I was so happy how the fitted tonight, the caliper position is fantastic also
  10. #30
    Veteran Skylar's Avatar
    Ken
    F series axle tube flange gasket layed over R/Z backing plate.
    Turned 90 degs
    Probably could make it work if you really wanted to but I'm not happy with it. Ba bow
    Twin caliper with integral handbrake it is.
  1. Disc brake rear end & S series ae86 diff
    By drift kid in forum Car Parts For Sale
    Last Post: 24th October 2012, 09:29 PM
  2. Replies: 3
    Last Post: 16th October 2011, 09:05 PM
  3. handbrake cables - T series disc brake diff.
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 15th October 2009, 09:16 PM
  4. T series Disc Brake Diff - Handbrake cables?
    By NIZLAH in forum Technical - Questions
    Last Post: 13th October 2009, 12:40 AM
  5. T Series Disc Brake Diff Housing
    By ke25 race in forum Car Parts For Sale
    Last Post: 19th March 2009, 10:20 PM
Tags for this Thread
