hey guys, going back to Toyota so s13 is going..
Silk road front / Kei office rears – base adjust - $800
D project castor arms – 80
ETS rack spacers x 2 – 100
Rear camber arms – 70
R32 modified x member 25mm forward – 180 changeover
5 stud s14 front with modified lock knuckles / r33 rear 5 stud with drift h/brake shoes – 1000 change over
Bride trims – 200 changeover
Bride seat brix (rip patched) on super low rail – 350
R32 Gtr passenger seat perfect cond. – 150
25mm quick release hub – 40
3 guage mount for s13 fits 60mm guages – 20
Rb25 gearbox / shifter/ slave/ x member / wiring./ speedo drive– 1350
Tailshaft rb25 into s13 - 250
Nismo 3 puck clutch / flywheel – 350
Rb30 forward facling intake – 350
Rb30 bottom end – spun bearing pulled down and ready for rebuild – 100 ono
Microtech LT10s / custom rb30 loom / tune for 350hp – 1000
Tige cam, performance double valve springs, performance adj cam gear (lumpy as) – 400
Rb nismo thermostat / used once for an hour – 80
Z32 hub / rb26 fan new – 80
R32 gtr radiator professional flushed – 150
Garrett 3071 .63 rear, 4 inch compressor housing, braided lines t3– 800
Rb30 highmount stainless turbo manifold – 150
R200 Tomei 2 way 3.9 gears – 750
Rb Grex oil cooler / new fittings – 350
CA lip – 100
S13 sunroof shell, no cracks in dash, raised rear strut towers, rear seam welded, sound dead removed, new carpet, complied, stock seats, most interior , non hicas -1500
Diff collars – 35
Exhaust – twin pipe cannon – 150
sms for pics 0402508041
located sunny coast
Rory.
