whats the smallest size wheel you can run with these kits?
We are proud to announce the supply of wilwood big brake kits for popular models.
Toyota, Nissan, Honda, Mazda, Mitsubishi, Subaru, Lexus, Chevrolet and even BMW
All kits include:
2 x Calipers (as specified)
2 x Rotors (as specified)
1 x set pads / caliper (Wilwood bp10)
2 x calliper adapter brackets
Braided stainless steel brake lines
grade 8.8 mounting hardware
Please read the underlined notes:
- All kits are a complete bolt on package.
- All kits unless specified use Wilwood Dynapro calipers.
- All kits come with Wilwood 2 piece rotors.
- All Kits come with plain rotors unless specified.
- Upgrade to slotted rotors for - $139/kit
- All callipers do NOT have dust seals.
- Dust seals can be added to the callipers when you order for $65 (cost is per kit, eg. 2 callipers)
We will be offering an ae86 complete front and rear big brake kit!
6 piston front - 298mm or,
4 piston front - 280mm
4 piston 254mm kit that fits some 13" wheels! (Front only, some wheels may require spacing)
4 piston rears with cable handbrake function - 280mm ( Powerlite rally calliper, standard cable needs to be modified )
Some kits are available with brembo or AP racing callipers. (POA)
All kits are specified for RACE USE ONLY.
Toyota: AE86
Front brake kits:
Ae86 - 4 piston 254mm kit, $1250
AE86 - 4 piston 280mm kit, $1250
AE86 - 6 piston 296mm kits, $1650
Rear Brake kits:
AE86 - 4 piston 280mm kit, $1195 (powerlite caliper pictured below)
Nissan: S13/14/15
please specify 4 or 5 stud hubs.
Front Brake kits:
S13 - 4 piston 327mm kits, $1395 (slotted Rotors standard)
S13 - 6 piston 327mm kits, $1695
Rear Brake kits:
S13 - 4 piston 300mm kits, $1550 (powerlite caliper pictured below)
Dynapro 4 piston W/O Dust boot
Dynapro 4 piston With Dust boot
Dynapro 6 piston
Powerlite Rally (ae86/S13 Rear)
Not the actual kit, image is of calliper and how cable mech works
Contact me with any questions or specifications you may have.
Joel
As above , 13" wheels with the 254 mm kit.
Some 14" wheels do fit the 280mm kit and some require spacing.
15" wheels are fine and need no spacing etc.
Thats awesome, good work joel.
I'm a hoarder of 13"s, so im mostly into the 254mm.
I'm looking forward to this![]()
DAMN! I sold my 13's so I fit the t3 wilwoods, haha.
so you go directly through wilwwod now or still through t3?
What would pricing be for a 280mm kit for a ke70?
No not through T3, Wilwood.
Still waiting for the freight costs so I can work pricing out.
Though there won't be a ke70 specific kit, you will need Ae86 struts.
I will post an application list once everything is finalized
still got a heap of stuff to do, all enquiries welcome
