Results 1 to 8 of 8
Thread: 4agte stalling
    Junior Member spooldog's Avatar
    BRAD
    YEPPOON
    Default 4agte stalling
    hey guys, i bought a sprinter reck with a 4agte in it i just got it running but iv ran into a problem with it, you go to put the clutch in when its in nutrual it wants to stall, has enyone had the same problem or knows whats going on?
    Sutherland
    fuel issue?, try crimp the return line to lift the rail pressure and see if you get a change.
    BRAD
    YEPPOON
    righto ill have a look thats 1 test i guss
    Mt Macedon
    So it idles fine in neutral? But then stalls if you step on the clutch?
    If so then it sounds like the clutch throwout bearing is siezed. Easy to replace but you have to drop the box.
    PS, some extra punctuation and paragraphs and stuff would make your posts a lot easier to read and understand.
    Sutherland
    Yeah I just read it again and Hen sounds on the money, I was thinking load issue...
    Senior Member adam's Avatar
    Adam
    If you're driving, going up to a red light and put the clutch in and stalls, chances are you've got a vacuum leak.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I had an issue with a clutch, where it would stall with your clutch pedal to the floor and the car in gear.
    Turned out that the fingers on the pressure plate were almost warn through, although the release bearing was fine. But so basically it wasn't totally disengaging the clutch.
    Oldschool Member
    Mar 2005
    Roy
    Bris
    ^^Also had this, I think it ended up being to do with master not adjusted enough and the clutch plate was slightly touching(Plate and everything was fucked when I pulled it out). Didn't like to start when warm. Never tried to start in Neutral though. Has since stopped with new clutch and master adjust. Not much of a help but yeah.
  1. random stalling and sputtering 4kc fml
    By shaunpierre in forum Technical - Questions
    Last Post: 19th August 2011, 01:12 PM
  2. 4AGE stalling?
    By RUF086 in forum Technical - Questions
    Last Post: 28th August 2009, 12:12 AM
  3. help me ke keeps stalling
    By mattie in forum Technical - Questions
    Last Post: 29th June 2008, 11:53 PM
  4. URGENT: Help - Stalling / Idle / Carb related
    By Javal in forum Technical - Questions
    Last Post: 18th March 2008, 08:38 PM
  5. Engine stalling problems when braking
    By Joel-AE86 in forum Technical - Questions
    Last Post: 23rd November 2006, 11:47 AM
